b18c type r swap into 99 civic si
Im in the midde of swapping the engine and find that my side mount and rear mount don't align. does anyone know if their are mounts made for this type of conversion?
Also i havnt' figured out how to do the wiring conversion. The engine is from japan. is there a harness or conversion that is manufactured to just plug in to both ends.
The last problem that i have is that it seems that the current cooling system will not be sufficient to cool this new larger engine. Has anyone run into this same problem? What should i do?
You need to change the mount that hooks to the block on the drivers side.
Use the harness from the b16
and the stock si radiator is sufficient.
And yes use the hybrid forum, us Hype R guys have no clue what were talking about when it comes to swaps, we like our stock motors
aaron you prolly want to check this link out.
maybe go a head and print it so jon can take a look at it
http://www.c-speedracing.com/h...p.php
Opo
Apr 22, 2010 03:54 PM
nexgen91
Mar 7, 2006 07:27 AM
sivik2nr
May 14, 2002 07:12 AM
