Tach wiring HELP!! 98 Civic DX
hey i have a civic dx and i just an ex gauge cluster and i have the male plug for the RPM's but i dont know where these four wires go... i have a pic below. can you tell me where each wire goes so i can make it work? thanks
lol thats the cruise control plug the vss wire comes prewired into the cluster connections as in all of them all hondas come prewired for tach even iof they dont have one
depending on the tach it will have some sort of switch or a wire for every cylinder type 4 6 8 choose accordingly then locate the vss wire and loacate a power and ground
this is the only plug that i dont have for my ex cluster so i was guessing it was the rpms.. what should i do to make it work?
it should be in the plug that runs to the speedo in the back of the cluster i forget which wire it is but ask around im sure someone will be able to tell u which wire is the vss in the back of the cluster
averyvm
Jul 15, 2008 01:21 PM
kent
Mar 2, 2003 06:23 PM
