Low and High oil pressure. Please read.
Old Aug 10, 2005 | 12:53 PM
Renegade's Avatar
Default Low and High oil pressure. Please read.
To start let's set what the oil pressures should be.
At idle : 10 psi minimum
At 3000 rpm : 50psi Minimum
My problem is
At idle the oil pressure is 60psi and on the head in VTEC the oil pressure is 25psi.
The pressure is high at the block and the pressure is low in the head VTEC oil passages.
Any ideas, I am going through the Acura service manual and going to check the Oil Jet and I guess the pump will be next. besides that I will take off th head and check the "head oil control orifice".
thank you
Old Aug 10, 2005 | 01:41 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Low and High oil pressure. Please read. (Renegade)
at 3k on my b16a i get 80-85 psi before the pressure relief valve opens, then it drops to 72-76 and climbs back to 80psi at higher rpm. What motor do you have? b16a b18c, or lsvtec?
Old Aug 10, 2005 | 01:58 PM
Renegade's Avatar
Default Re: Low and High oil pressure. Please read. (PURPLETERROR)
sorry I should have specified the motor.
it is a B18C5 ITR
The values I posted were from the service manual and the 60 psi reading was from the block pressure, where the pressure sensor is next to the oil filter, the Head reading was done while driving from the opening next top the VTEC solenoid.
Old Aug 10, 2005 | 03:39 PM
drdisco69's Avatar
Sounds like the bypass valve in the oil pump isn't releasing as much pressure as it needs to be. I haven't seen that happen before though, they're usually foolproof.
Old Aug 11, 2005 | 02:57 PM
Renegade's Avatar
it is a B18C5 ITR
Renegade
Feb 21, 2008 09:07 AM
powerdbygarrett
Jan 5, 2008 04:35 AM
coupon
Jun 7, 2005 11:54 AM
r7
Aug 19, 2002 06:34 AM
