got some new springs!
Old Aug 10, 2005 | 12:21 PM
DualCamDan's Avatar
Default got some new springs!
but i havent done any springs in over 2 years, so which ones go in the front and which go in the back? i was told the ones that are tightly wound at the bottom are for the rear, and the taller ones for the front... is that right? they look like this, but they are a differant color.
trying to get em' done, any help will be awesome!
Old Aug 10, 2005 | 12:24 PM
Tyson's Avatar
Default Re: got some new springs! (singlecamdan)
yeah, thats typically how they go. the rear ones are going to be more progressive and the fronts are more linear. its not ALWAYS the case, but most of the time.
Old Aug 10, 2005 | 12:31 PM
DualCamDan's Avatar
Default Re: got some new springs! (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">yeah, thats typically how they go. the rear ones are going to be more progressive and the fronts are more linear. its not ALWAYS the case, but most of the time.</TD></TR></TABLE>
progressive = closer?
linear = spread out?
and i close to what you meant at least?
Old Aug 10, 2005 | 12:32 PM
Tyson's Avatar
well, progressive means the rate changes. the springs on the left are tightly wound and then are loosely wound. thats progressive. the springs on the right are nearly constant, except a bit at the bottom. so its still a bit progressive, but mostly linear.
Old Aug 10, 2005 | 12:38 PM
DualCamDan's Avatar
cool, thanks a lot man!
Old Aug 10, 2005 | 01:21 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Look at the thickness of the spring. The thicker ones go in front
ef8cybercrx
Mar 5, 2008 06:19 PM
1.8L_allmotormilitia
Suspension & Brakes
Aug 20, 2007 01:46 PM
allricedout
Suspension & Brakes
Mar 17, 2007 12:23 AM
Solracer
22
Nov 3, 2004 02:47 PM
2 point 0
30
Apr 10, 2004 08:52 PM
