After Seafoam..
after i did seafoam in my car i changed my oil and all my spark plugs..and the car runs a lil smoother..is there anything else i should change? because when i start my car up i hear crackling noises a little from the enginebay..maybe i should change my radiator coolant? i dont know..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_c »</TD></TR><TR><TD CLASS="quote">I would hate to get flamed for asking but I never heard of doing a seafoam. Is that a type of engine cleaner?? </TD></TR></TABLE>
Basically cleans out all the carbon deposits in your engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DynastyRacer22 »</TD></TR><TR><TD CLASS="quote">after i did seafoam in my car i changed my oil and all my spark plugs..and the car runs a lil smoother..is there anything else i should change? because when i start my car up i hear crackling noises a little from the enginebay..maybe i should change my radiator coolant? i dont know..</TD></TR></TABLE>
Wheres the noise coming from?...after i used seafoam i heard a crackling noise too, it was coming from around the timing belt...didnt think much of it at the time but next day my timing belt broke
....im not blaming seafoam, but this sounds a bit too familiar, wouldnt want the same to happen to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h4x »</TD></TR><TR><TD CLASS="quote">
Basically cleans out all the carbon deposits in your engine.</TD></TR></TABLE>
I've used BG fuel/ induction system cleaner, pretty good stuff! It gets sprayed in thru the throttle body while the car is running, and then a seperate cleaner goes in the gas tank.
Back to the original topic, sorry I couldnt be of any help.. I'm clueless as to what maybe causing that noise. Good luck.
I've used BG fuel/ induction system cleaner, pretty good stuff! It gets sprayed in thru the throttle body while the car is running, and then a seperate cleaner goes in the gas tank. Back to the original topic, sorry I couldnt be of any help.. I'm clueless as to what maybe causing that noise. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DynastyRacer22 »</TD></TR><TR><TD CLASS="quote">nope i bought the car a year ago and the timing belt was already replaced at the dealer</TD></TR></TABLE>
i wouldnt trust a dealership unless i actually had proof of them changing the timing belt...but just to be safe you should take off your valve cover and do a visual inspection (for watevr thats worth)...if your timing belt breaks while your driving theres a very good chance that you might bend some valves...better safe than sorry right?...i dont think you would want to go through the hassle of repairing and or buying a new head...juss my .2 cents
