anyone have a pic or know where to cut the body for fuel pump
Old Aug 10, 2005 | 09:13 AM
alexsracing's Avatar
Default anyone have a pic or know where to cut the body for fuel pump
to make it into a 92 and up style for changing
Old Aug 10, 2005 | 09:27 AM
91civicEX's Avatar
Default Re: anyone have a pic or know where to cut the body for fuel pump (alexsracing)
why not just drop the tank? its pretty easy. just the two straps and take a couple hoses off. should take about 30min
Old Aug 10, 2005 | 09:36 AM
already did that, abd it gets old. ned to check stuff.
have a few efs
Old Aug 10, 2005 | 11:32 AM
bump
Old Aug 10, 2005 | 06:01 PM
Default Re: (alexsracing)
never mind got it done.
Old Aug 10, 2005 | 06:20 PM
crxgator's Avatar
are you ******* kidding me? you cut open your car to get to the fuel pump? ******* smart...
Old Aug 10, 2005 | 06:48 PM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: (crxgator)
thats really retarded, even if you opened it up you cant take it out. Theres lines that need to be unhook on the side of the tank.
Old Aug 10, 2005 | 06:50 PM
rough_draft's Avatar
wow
Old Aug 10, 2005 | 06:57 PM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: (rough_draft)
I wanna see you weld that up, HAHAHHAHAHAHAHHAhA
Old Aug 10, 2005 | 07:04 PM
xtrafastcivic's Avatar
Default Re: (NAS_OCSICNARF)
he said check stuff not remove.. there has to be a good reason for him doing this . i hope
Old Aug 10, 2005 | 07:30 PM
it can be covered with a peice of sheet metel and self driling screws
Old Aug 10, 2005 | 07:33 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
i dont know about that....
Old Aug 10, 2005 | 08:31 PM
Fobtions's Avatar
Default Re: anyone have a pic or know where to cut the body for fuel pump (rukawa1one)
maybe reattach the part you cut off, and have a lil trap door?
good luck
Old Aug 10, 2005 | 09:16 PM
1320spTurtle's Avatar
Why wouldn't you just drop the tank??? it's not even hard at all and definately not worth cutting up the car for.
*edit* didn't read it all the way, well i guess you do what you gotta do
Old Aug 10, 2005 | 10:39 PM
wrXtian's Avatar
wow if you ever go to sell the car i hope you tell the potential buyers about that.
Old Aug 11, 2005 | 09:29 AM
nothing goes in that spot anyways , its behind the seats and before the spare tire compartment.
honda started having trap doors for 92 and up, so I don't see why this is a problem
Old Aug 11, 2005 | 09:36 AM
Reelizmpro's Avatar
Actually, I thought about doing the same thing but after replacing the fuel pump for the first time a few weeks ago i could probably do it again in like 30 min or less. The car and tank is small so it's not bad at all and I did it on the ground in my garage by myself. Would be easier on a hoist especially with a partner. I think you'd have to cut the hole a lot bigger than that though because of the hardline.
redtegra
Mar 15, 2008 06:56 PM
Civic92Turbo
Sep 25, 2004 07:57 PM
EGJDM
Sep 21, 2004 07:02 PM
AllMotorGSR94
Feb 19, 2004 03:08 PM
Ideal
Nov 7, 2002 09:22 AM
