head gasket help!!
Old Aug 10, 2005 | 09:09 AM
silentbeatz's Avatar
Default head gasket help!!
1993 cx
i am about to replace my head gasket and the only thing i am worried about is the timing belt since i have little experience with it. since im only changing the head gasket, would i have to totally remove the timing belt or could i just slip it off? would i have to remove the crank pulley bolt that everyone has trouble with?? thanks everyone.
Old Aug 10, 2005 | 09:12 AM
Luserkid's Avatar
Default Re: head gasket help!! (silentbeatz)
Just slip it off. Have everything at TDC first and your set.
Old Aug 11, 2005 | 10:06 AM
doublejz's Avatar
Default Re: head gasket help!! (Luserkid)
since its a sohc just line up the tdc marks now before you pull the head and dont turn the crank or cam. take the belt off, pull the head, change gaskets, put the head back on and put the belt back on. timing belts on sohc are really easy. just dont forget that damn L - bracket on the back of the head and block that connects them together. I hate that thing, hehe
Old Aug 11, 2005 | 10:08 AM
b204dr's Avatar
ive never changed a single cam but wouldnt the cam gear but to tight to simply "slip" back on - i would suggest changing out the timming belt, and the water pump at the same time to safe your self the hassel( at a later time that is
Old Aug 11, 2005 | 10:10 AM
doublejz's Avatar
Default Re: head gasket help!! (doublejz)
i wouldnt recommend using old parts but some people do. Heck I had to rebuild my bottom end last month, water pump, oil pump, timing belt and tensioner had like ~25,xxx miles on it but i still replaced it all.
Old Aug 11, 2005 | 10:16 AM
turboedd15b's Avatar
Just slide off the belt and make sure you get new head bolts. Line up all of your tdc marks and adjust the valves and youll be good to go.
Old Aug 15, 2005 | 10:51 AM
thanks everyone
Old Aug 15, 2005 | 06:09 PM
BLOODTYPEH's Avatar
Default Re: (silentbeatz)
make sure that the old head gasket is not stick to the surface of the cylinder head before installing the new one. Major leak problems occur and youll eventually loose compression and oil.
Old Aug 15, 2005 | 06:44 PM
revhard_si's Avatar
Yeah u actually have to remove everything but before u do,remember how it was placed.n ofcourse make sure to clean before putting the headgasket n then the glue sealer n make sure about the timing belt ....best advice is to have it done by somebody thats famaliar....good luck
jermo
Honda Civic (2001 - 2005)
Jul 30, 2014 02:26 PM
B_Swapped93
Dec 17, 2012 03:07 PM
nicknack25
15
Oct 26, 2010 08:16 PM
niceguyjp2183
May 9, 2006 02:51 PM
Mr. Thunderlips
Nov 7, 2002 11:18 PM
