clutch problem..engine cant be rotate.
Old Aug 9, 2005 | 10:26 PM
vteczone's Avatar
Default clutch problem..engine cant be rotate.
ok,here is my problem.i installed an Action 2MD clutch onto my B16 tranny,its my first time installing an aftermarkets clutch.before i install,the engine can be rotated easily..so what sort of installation error of the clutch that will cause it to engage the jam the motor?
Old Aug 9, 2005 | 11:51 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: clutch problem..engine cant be rotate. (vteczone)
is your trans in neutral?
Old Aug 11, 2005 | 10:47 PM
vteczone's Avatar
i found out what the problem was.it wasnt the clutch problem.it was a mistake i made putting a longer screw for the front mount which poke out to farin a hit the flywheel n jammed the whole motor..haha..worst thing was i found that out when i disambled the whole tranny when i could have justchangethe screw with a shorterone...
bigluelok
Transmission & Drivetrain
Dec 12, 2010 05:00 PM
SSJSubgeta
Oct 22, 2005 12:20 PM
SpOoNisMyFriEnD
May 11, 2005 02:18 PM
doublejz
Oct 20, 2003 09:54 AM
Beave0101
Mar 23, 2003 08:36 AM
