B18c1 head needs valves..stay b18 or goto b16 head?
Old Aug 9, 2005 | 09:04 PM
1990hondaHF's Avatar
Default B18c1 head needs valves..stay b18 or goto b16 head?
at least one valve is bad on my head...(175 or less comp)....since the head will be off and I'll be spending money, is now the time to "upgrade" to a b16 head or just keep the stock head? The reason I ask is because, I've read a few posts about how the b16 head flows much better then the stock b18c1 head does....thanks for the info!
Old Aug 9, 2005 | 09:13 PM
turbotommy's Avatar
Default Re: B18c1 head needs valves..stay b18 or goto b16 head? (1990hondaHF)
poor mans itr eh?
i would stick with the p72 head, just replace your valves with oem replacements and upgrade your valvesprings. rock solid oem setups are the best!
Old Aug 9, 2005 | 11:32 PM
PURPLETERROR aka BIGMATT's Avatar
Order a set of omnipower valves, get a valvejob and new guide seals and you will be good to go. You will loose compression by switching to a b16a head.
Corksil
14
Jan 26, 2013 09:09 PM
96ej8MR
Jun 27, 2007 05:37 PM
B18CRMiKE
Aug 21, 2005 01:52 PM
joshonater
Oct 3, 2004 11:36 AM
Beave0101
Mar 10, 2004 07:44 PM
