what kind of whp numbers are you getting w/ b20block/b16 head in integra.
Old Feb 21, 2002 | 03:09 PM
threatcon13's Avatar
New User
Default what kind of whp numbers are you getting w/ b20block/b16 head in integra.
as topic says..this is what my friend planson getting. I was wondering just stock after dropping in what numbers it produces..assuming no boring,stroking,pistons, just bone stock ....thanks
Old Feb 21, 2002 | 05:19 PM
tinkerbell's Avatar
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (ALLMOTORDC2)
PLUS
interested in how high these combos rev to and where the powerband is at...
Old Feb 22, 2002 | 05:19 AM
BoM's Avatar
BoM
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (tinkerbell)
extensive building of the bottom end will be required to make it reliable not much just money.
pistons and rods and an internal girdle from a GSR.
on the head all thats needed is to enlarge the dowels to 14mm
i/h/e of course
bolting it together will get you 150-60whp 130-40lb - STOCK and low redline
complete built bottom with hi compression pistons 12:1 + you will net
180whp 140ft/lb
with some luck you drop in some ITR cams you can break 200whp.
8500 is a safe number with the girdle installed.
Old Feb 22, 2002 | 06:38 AM
acura_typer's Avatar
Banned
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (BoM)
Your numbers are a bit low.
Ive seen just buildups get 210-220whp, 130-140tq
Just bolting it together will net 175-180whp.
Old Feb 23, 2002 | 04:18 AM
Ri5e's Avatar
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (acura_typer)
Yeah I agree, 150-160 WHP is almost stock GS-R ish power...
Old Feb 23, 2002 | 04:56 AM
BoM's Avatar
BoM
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (BG Boost)
numbers are numbers they vary.
i personally think its better to rate them lower,
so u can get suprised. Better to be modest
than optimistic and not achieve those numbers
and getting 210whp isn't ez. your talking about 8-10 grand.
Old Feb 23, 2002 | 06:55 PM
ezark's Avatar
i couldn't agree ANYMORE.
Old Feb 25, 2002 | 06:27 PM
battyx's Avatar
Well, considering that I was quoted $4800 to get my GSR pushing 220-225whp all motor by a well respected shop, I think your prices are a little high. It is always smart to be conservative when spouting out hp numbers though.
Can you expand more on this girdle? I'm the one who's doing this motor swap, and I need it to be as reliable as possible. If anyone w/ experience can tell me what needs to be done to keep a cr-vtec reliable I'll be very thankful.
Old Feb 26, 2002 | 10:09 PM
l's Avatar
l
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (battyx)
.Well, considering that I was quoted $4800 to get my GSR pushing 220-225whp all motor by a well respected shop
what shop is this???
Old Feb 27, 2002 | 09:40 AM
New User
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (IM ALL SHO)
this shop is importbuilders in fullerton.
Old Feb 27, 2002 | 09:58 AM
Trey's Avatar
25 Year Member
Here is the girdle to get:
http://www.z10eng.com/z10_products.htm
Old Feb 27, 2002 | 11:16 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (Trey)
Hey Trey are we going B20???????
Old Feb 28, 2002 | 10:39 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (Apex i ITR)
Thats a nice piece!
Old Feb 28, 2002 | 01:45 PM
battyx's Avatar
Hmm. On the webpage it says that it says this:
NEEDS!
*GS-R / Type R
Main Bolts, Windage Tray, Oil pump pickup
( not included )
Since my crvtec is going to be a b20 block with a b16a head, does that mean it's not going to fit?
Old Feb 28, 2002 | 06:39 PM
crxfactor1991's Avatar
it will fit, you just need to replace the 6 middle crank bolts, the windage tray, the pickup and the pan with GSR parts
expect to pay the same amount for the accessories as you will for the girdle
Old Mar 1, 2002 | 12:14 PM
battyx's Avatar
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (crxfactor1991)
Well, one more question on this piece. Is it worth it? If it makes the engine more reliable and safer then I'll definately get it.
Here's another question for anyone who knows their stuff. How much power and what time do you think this set-up will run in a 94' integra weighing about 2900lbs.?
Cr-vtec w/ jdm itr headers, skunk2 intake manifold, aem cold air intake, and a Z10 girdle.
Old Mar 3, 2002 | 10:24 PM
battyx's Avatar
TTT.
Old Mar 3, 2002 | 10:52 PM
88crxoncrack's Avatar
hey, most NA draggers are putting out only like 220 or so whp, it's not all that hard, but it's money. oh, and that Z10 girdle is awesome.
Old Mar 4, 2002 | 04:50 AM
ImportechPerformance's Avatar
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (88crxoncrack)
Im sorry but can i ask a dumb question? ok. What is or better said what does it(girdle) do?
and do all b-series VTECs have it?
[Modified by MrPimpon, 6:52 AM 3/4/2002]
Old Mar 4, 2002 | 06:54 AM
Bnjmn's Avatar
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (MrPimpon)
The girdle braces the crankshaft mains so that the crankshaft doesn't "walk" in high rpm/hp applications.
You can find the GSR girdle parts much cheaper than the Z10 piece, though they won't be as shiny.
Ben
JeffNA's Avatar
The girdle is good for keeping the crank intact. CRV motors are not made for high reving or top speed cause the pistons and rods are not made for that.
Old Mar 4, 2002 | 08:32 AM
bojangs's Avatar
New User
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (Bnjmn)
excately.. if you're into saving money go with the modded gsr girdle.. it will work just as well..
Old Mar 4, 2002 | 08:56 AM
stizzit's Avatar
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (bojangs)
My car see's 9500rpm once and a while, all other times about 8500. I don't have a z10 girdle and don't plan on getting one. Honda's have some of the best crankshafts i've ever seen. The only thing that needs close attention to is bearings. But girdle or no girdle, it won't last as long as a stock motor at those rpm's. B20/vtec fully built top to bottom. There is no reason for my motor to see 9.5krpm unless i'm showing off (but man it sounds mean), power rolls off well before then, around 8krpm. Just my opinion and i have no way to prove it but have you noticed what domestic main girdle's are made of? you don't see any aluminum ones do you? thats what i thought .
Old Mar 4, 2002 | 12:36 PM
battyx's Avatar
Default Re: what kind of whp numbers are you getting w/ b20block/b16 head in integra. (stizzit)
Ok, so the girdle sounds like a good idea. I'll get it. That means my set-up will basically be this when done:
Cr-vtec w/ AEM cai, Skunk2 intake manifold, Toda B spec cams, Toda valve springs, Toda cam gears, Skunk2 intake manifold, Z10 girdle, and Greddy exhaust.
Anyone have an idea what kind of power this is going to put out? And will I need a V-AFC and/or a chip?
Thanks a lot.
Old Mar 4, 2002 | 07:39 PM
l's Avatar
l
hey, most NA draggers are putting out only like 220 or so whp, . .
yeah 220whp is for the NA street cars....
220whp race car isnt much.....
93delslow315
Sep 23, 2010 01:04 PM
Type R 00
Jan 26, 2007 06:42 PM
blowme
Mar 10, 2006 11:23 AM
BlowenGT
20
Feb 17, 2004 09:15 PM
RacerDre
Sep 22, 2002 01:54 PM
