91 civic cx radiator size
hi
I dont really hang around this section of the forum .. i do it on the eg forum
i need to find info about the diferent sizes of radiators of the 91 civic cx/dx/si trim ,, because my father resently blew his radiator and I went to a used auto parts to find one and I bough a radiator that was a little bit bigger ,, i even went to pepboys and it was bigger than the original radiartor .. anyone know if they are diferent sizes or something ... my gess is that the si is bigger than cx/dx because it need better cooling .........
the car is a 1991 civic hb i cant tell wich trim is but this one doesnt have tach ,
dont know but I have tryed every radiator that exist on this world .. btw to help you guys help me this is my vin #
2h6ed6344mh54421
I think is a ed6 on the side of the door say's 03/91 and in the front engine frame say's
mfd . by honda canada mfg.
clor type r63.4 hope you guys help me on this one
2h6ed6344mh54421
it doest not fit through the frame .................. on pepboys,napa,advance auto zone they clam that is a 91 civic radiator but is kinda bigger the one they sell mine is a little bit smaller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR »</TD></TR><TR><TD CLASS="quote">hi
the car is a 1991 civic hb i cant tell wich trim is but this one doesnt have tach ,</TD></TR></TABLE>
The 1988-1991 Civic STD (called CX in other countries) uses a narrower radiator than other 1988-1991 Civic models. But ALL 1988-1991 Civics can accommodate EITHER radiator. And if you are buying an aftermarket radiator, chances are the aftermarket manufacturer just makes a single model (ie non-STD) since the non-STD radiator will fit ANY 1988-1991 Civic model AND provide enough cooling. So don't worry about using the bigger radiator. If anything, it will be better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">The 1988-1991 Civic STD (called CX in other countries) uses a narrower radiator than other 1988-1991 Civic models. But ALL 1988-1991 Civics can accommodate EITHER radiator. And if you are buying an aftermarket radiator, chances are the aftermarket manufacturer just makes a single model (ie non-STD) since the non-STD radiator will fit ANY 1988-1991 Civic model AND provide enough cooling. So don't worry about using the bigger radiator. If anything, it will be better.</TD></TR></TABLE>
thank you
but one thing ... the normal radiator that they sell dont fit on my car ...... the frame is too small in order to fit the radiator ?
thank you
thank you
but one thing ... the normal radiator that they sell dont fit on my car ...... the frame is too small in order to fit the radiator ?</TD></TR></TABLE>
Install the radiator with the top tilted to the beck in order to fit under the radiator support. Then seat the bottom mounting pegs in the grommets and bring the top back. It should fit. If it doesn't, make sure the bottom is indeed seated.
thank you
WhiteOnRice
13
Oct 28, 2007 06:57 PM
subgeniusdude
Apr 20, 2003 09:42 AM
