Omni Master Cylinder Clutch!
Old Aug 9, 2005 | 07:49 PM
digital sol's Avatar
Default Omni Master Cylinder Clutch!
ok well, just wanted to check in, i waited 1 month without my car to get this part instead of the oem unit. I installed it properly, it worked properly for 1 week. My clutch pedal began to sink to the floor like it did with the blown oem part. I therefore figured it had to be my master slave cylinder so i replaced it. Spent 3 days trying diff bleed methods and playing around with everything i could. I then said **** it, and removed the omini master cylinder sense something obviously wasnt right at the start.
surely enough, after 3 days without my car, countless headahces, backaches and so fourth the brand new unit from Omni is already broken, i put 75 miles on it
the cylinder is seized, the rod seems to be broken internally and not attached to the cylinder.......guess i get to call first thing tomarrow mourning and see how long im without my car........again
Old Aug 9, 2005 | 08:26 PM
VX's Avatar
VX
Default Re: Omni Master Cylinder Clutch! (digital sol)
Same exact damn thing happened to me last week. It installed fine, and worked for about a day and a half. I noticed the clutch pedal slowly getting lower to the floor.
I go get a hair cut for 20 min. walk outside back to my car, and the clutch pedal is on the floor. After pumping/cursing at the pedal for 5 min. It rises enough for me to drive home safely.
I popped the hood and attempted to bleed my clutch for a while w/ no luck. no liquid was coming out of the clutch slave cylinder. I tried different bleeding methods but the brake fluid was never being sucked down through the system passing through the clutch master cylinder.
I disconnected the line leading out of the MC. and just tested to see if the MC would suck/squirt out the brake fluid from the reservoir... no luck.
Luckily Omni has a 5 year warranty on this, and Peter at Import Auto Performance just told me to send in the faulty unit to them today in exchange for a brand new one... we'll see...
Old Aug 9, 2005 | 08:29 PM
Default Re: Omni Master Cylinder Clutch! (VX)
same thing
damm, i just hate having to deal with this ****, because its my daily driver and its been down 3 days, now probably at least another week to get a replacement unit in, and with my luck its gonna probably be broken before i even get it
Old Aug 9, 2005 | 08:37 PM
VX's Avatar
VX
After you get your replacement installed and have driven w/ it for a while, check in here and post if it's running strong or having the same symptoms as before.
I'll make sure to post up my experiences w/ my replacement MC.
BTW: Where did you purchase yours?
Old Aug 9, 2005 | 08:48 PM
underb00steg6's Avatar
i was thinking about getting this product. is there some kind of defect with this product?
Old Aug 9, 2005 | 08:52 PM
VX's Avatar
VX
Default Re: Omni Master Cylinder Clutch! (underb00steg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking about getting this product. is there some kind of defect with this product?</TD></TR></TABLE>
The product is still new, and this is the first negativity I've heard about it. I'll know in due time when i receive my replacement MC if Omni designed a poor product or not.
Old Aug 9, 2005 | 09:01 PM
VWVORTEX's Avatar
blah you gotta be shitting me.. i just sent omni an email that mine was junk and i come on honda-tech and this is the first thread i see.. lol..
i'll try to post some pics.. kinda pissed its been only 2 weeks and its broken.
i hope i get my money back.
Old Aug 9, 2005 | 09:02 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Omni Master Cylinder Clutch! (GripStar)
Wheres Omniman? I was gonna buy this... but not if its a POS.
Old Aug 9, 2005 | 09:17 PM
i bought mine from robear racing http://www.tornactive.com/
i hope they take care of me and dont try and make me pay for shipping or any of that bs, im pissed its already ******* broken
ill be sure to post what happens, and ill post back up once i re-install the replacement unit and keep in touch about it
apparently there is a defect considering there are already 3 broken master cylinders that all broke with only 2 weeks use, the product is still new, all i know is the replacement part better not ******* break again or im gonna choke a bitch
Old Aug 9, 2005 | 10:43 PM
VWVORTEX's Avatar
yea it's def pretty weak, but robear rocks.. i must get atleast half my stuff from robear, i got there tow hooks, got my chamber kit, and some cam gears from them.. def a place i trust. So sick of having to worry about where to order my ****.. weridspeedlab fucked me over, omni is ******* me over, atleast robear is cool
Old Aug 10, 2005 | 04:26 PM
kevs_92gsr's Avatar
I just bought the omni **** too and Its only been 4 days and my **** went. Same thing as you guys, really pissed me off. And its my daily driver. I also sent an email to the people I ordered it from(Import Auto Performance), still waiting for a reply. Hopefully I can get my money back. I'll keep you guys posted. haha and if they send me another and that **** breaks Iama choke a bitch too haha
Old Aug 10, 2005 | 04:53 PM
VX's Avatar
VX
Default Re: (kevs_92gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX & Peter@IAP &raquo;</TD></TR><TR><TD CLASS="quote">(3:24 PM 8/10/2005) VX: About the MC. there's a thread on H-T about how they are faulty: https://honda-tech.com/zerothread?id=1334993
If these break on me again, is it possible to return them for a refund?
(3:49 PM 8/10/2005) peteriap: Absolutely. The problem is being looked into now and we will keep all of our customers up to date on any findings.
(3:53 PM 8/10/2005) VX: thank you so much man. I'll keep in touch with you and others about my experiences w/ my replacement MC.
(3:53 PM 8/10/2005) peteriap: Sounds good. OMNI may be coming out with a <FONT SIZE="12">revision</FONT>, do you want to wait on that one? I would imagine that you do. Let me know.</TD></TR></TABLE>
Looks like they're faulty after all!
And a revision is in the progress!
My car is currently a brick.
Peter @ IAP for taking care of his customers.
Old Aug 10, 2005 | 04:56 PM
kevs_92gsr's Avatar
hopefully IAP hooks me up too, I'll be waitin for the revised one as well. Looks like my cars a brick as well
Old Aug 10, 2005 | 06:44 PM
suckers
i put my leaky stock part back on for now.....too bad my car still needs a new master brake cylinder before it can leave the driveway......
im gonna wait for the revised unit as well, just hope this leaky oem piece can hold for a month
Old Aug 10, 2005 | 06:52 PM
TorganFM.'s Avatar
Default Re: (digital sol)
Wow, this sucks. I was really considering one down the road sometime . Even if there is a revision this is something that should be caught in testing. It really sucks blowing a master cylinder. One day after school I got in my car and I had no pedal pressure and there was fluid all over my floor. I made it home with about a millimeter and a half of clutching, I bet I really toasted it then.
chad's Avatar
Moderator
hmmm...omni products in general have a great reputation
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote"> the brand new unit from Omni is already broken, i put 75 miles on it</TD></TR></TABLE>
A guy local to me had one that went out after only 30 miles of driving...
Old Aug 10, 2005 | 07:10 PM
kevs_92gsr's Avatar
Default Re: (DanW)
well damn if there not comin out for another month with the revised ones then I'll be gettin me a stock one from carquest or somethin even though I really dont want a reman one.
Modified by kevs_92gsr at 4:21 AM 8/11/2005
Old Aug 10, 2005 | 07:18 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
that sucks cuz i was looking in to getting that product too. But it just came out and u guys are the first to try it right? They probably havent worked out the bug yet, and hopefully over time they will have the new gen without the probs
Old Aug 10, 2005 | 08:14 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: (rukawa1one)
I PM'd Omniman to see if he would join this thread. No response yet...
Your right though, Omnipower has an excellent reputation. Looks like they sent this to the market too fast.
Old Aug 10, 2005 | 09:28 PM
VX's Avatar
VX
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Looks like they sent this to the market too fast.</TD></TR></TABLE>
I don't see why, not like there's any other aftermarket companys to compete with to release such a product. Hmmm...
Old Aug 11, 2005 | 01:52 AM
Toxidomask's Avatar
hehehe that sux dude, im one of the first ones to have this. but i havent had the time to install it.. I wonder if I should wait and have it replaced with a revision one. what you guys think? havent heard of many broken ones yet, but i have a bad feeling. I got mine from Kteller, and he says its lifetime warranty. but if i havent even installed it yet? and its considered not broken what warranty covers that?
Old Aug 11, 2005 | 02:09 AM
wanabericer's Avatar
holy crap and i was going to buy this too.........
Old Aug 11, 2005 | 02:28 AM
VWVORTEX's Avatar
Default Re: Omni Master Cylinder Clutch! (EGangel)
With this level of incompetence, I'm staying away from buying omniman products in the future. I suggest everyone does the same as well...
Old Aug 11, 2005 | 03:22 AM
james p.'s Avatar
At first I was hearing great things about Omnipower but after a bad rap with the suspension just last week and now this... I was considering getting some stuff and now I'll just stick OEM for the time being.
After hearing so many good things about Omniman himself, I don't think he would release a faulty product that hasn't been road tested.
I want to hear from Omni himself before I make a conclusion.
