anyone have an obd 2 motor in a obd 0 chassis???
I am wondering if anyone here has an obd 2 motor in a obd 0 chassis and if so what is your setup? I am having trouble getting my motor to run right. Currently I have a b16b in my 89 si. I am using a obd 0 first gen b16 distributor, injectors, and the pr3 computer. It does not feel like it has the power it should and I am also throwing a code two for the oxygen content. I am pretty sure that this is due to running rich. My idle is erratic and I tried to block off my iacv but then it feels real sluggish. I don't know if this computer is doing this engine justice or maybe I should go to obd 1. Is there anyone out there that has any info on this or has done this swap before suucessfully? If anyone can post their setup I would appreciate it. I just want this thing to run right because it is my daily driver. Does anyone know of a knowledgable tuner that is in pittsburgh pa? PLease help. thank you
Well bro do you have both oxygen sensors hooked up? if not thats why you're throwing a code 2.
Your best bet imho is to upgrade to obd1 using a chipped p28.
<-----Will be running OBD1 using OBD 2 dizzy, injectors, etc. on my JDM B18c (r), pretty much same thing you have. Do you still have the obd2 equipment?
http://www.rywire.com
I still have the injectors that came with my motor. So basically all I need is the b16b injectors back, the conversion harness to go to obd 1, and an obd 1 or 2 distributor with an obd 1 p28 computer? What about the resisitor box? Do I need this to convert to obd 1. Sometimes I wish I'd just had swapped in a first gen obd 0 b16a. I would have been cheaper and it would have ran better. This is turning into a real nighmare. Please let me know how you plan to run your b18c obd 1 swap. I sure would appreciate it. Thank you.
I am using an OBD2 B18 engine in my car.
I used the OBD2 injectors, no resistor box, and an OBD1 dizzy and ECU. (with obd1 ECU harness)
I made my own ECU program to make use of the 1800cc maps. Runs like a dream.
I suggest you fix your code before deciding to ditch OBD-0 and blow more $ into OBD-1.
You have the proper setup and it should be running just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r2d97 »</TD></TR><TR><TD CLASS="quote">I still have the injectors that came with my motor. So basically all I need is the b16b injectors back, the conversion harness to go to obd 1, and an obd 1 or 2 distributor with an obd 1 p28 computer? What about the resisitor box? Do I need this to convert to obd 1. Sometimes I wish I'd just had swapped in a first gen obd 0 b16a. I would have been cheaper and it would have ran better. This is turning into a real nighmare. Please let me know how you plan to run your b18c obd 1 swap. I sure would appreciate it. Thank you.</TD></TR></TABLE>
As 4drEf said, its probably best to trouble shoot the codes you have first and get it running, but I would definitely convert over to obd1 somtime in the future.
I will be running my OBD 2 injectors and distributor on my modified stock harness from http://www.rywire.com and the OBD0-OBD1 conversion harness from (blownhatch = http://www.jkobd.com and also supplied through rywire). I have a chipped p28 (OBD1) that I will also be using. I chose to have someone else do my wiring b/c I didn't feel like having down time trying to chase electrical gremlins. At least if i have a pro do it I am pretty much guaranteed that everything will plug right up and run.
You could also DIY and there are plenty of wiring diagrams online along with plenty of people to help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r2d97 »</TD></TR><TR><TD CLASS="quote">what about the oxygen sensor? You have to have a four wire oxygen sensor too I beleive to have obd 1 conversion.</TD></TR></TABLE>
true
true
Guest
Posts: n/a
and get the OEM cause I heard tons of stories about aftermarkets.
