spoon cams breaking?
Old Aug 9, 2005 | 05:32 PM
ITR#465's Avatar
Default spoon cams breaking?
I dont know much about cams, so I want to ask the experts. I bought the itr with spoon cams and spoon cam gears, when Im driving on the freeway, the cams sounds so loud that like its gonna break, just want to know is that normal?
Old Aug 9, 2005 | 05:34 PM
jetydosa's Avatar
25 Year Member
Default Re: spoon cams breaking? (RedLineDC2R)
Did you get them installed at Pep Boys?
Sorry couldnt resist old sk00l ITR forum joke.
I cannot imagine that noise would possibly be normal.
Old Aug 9, 2005 | 07:29 PM
ITR#465's Avatar
Default Re: spoon cams breaking? (Jetydosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">
but I thought aftermarket cams are louder than stock....
Old Aug 9, 2005 | 07:40 PM
ITR#465's Avatar
anyone else have experienced it?
Old Aug 9, 2005 | 07:54 PM
Tweakmeister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">Did you get them installed at Pep Boys?
Lol good one (check the crank pulley for a missing wrench )
It's kind of a bit vague here - are you sure it's from the valvetrain/cams?
Old Aug 9, 2005 | 11:15 PM
rodimus's Avatar
Default Re: spoon cams breaking? (Tweakmeister)
you're in the bay area..there's some good shops out there..have someone check it out for you.
Old Aug 10, 2005 | 12:40 AM
ITR#465's Avatar
Default Re: spoon cams breaking? (EVOL)
but it runs without any problems
Old Aug 10, 2005 | 12:43 AM
ITR#465's Avatar
anyone have aftermarket cams? what does yours sounds like?
Old Aug 10, 2005 | 01:05 AM
B2FiNiTY's Avatar
The spoon cams I had sounded like stock.
Even pepboys installed
Maybe need the valves adjusted?
Old Aug 10, 2005 | 03:25 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLineDC2R &raquo;</TD></TR><TR><TD CLASS="quote">but I thought aftermarket cams are louder than stock....</TD></TR></TABLE>
they are louder than stock in the sense that when you romp on it, it will make the engine sound louder and meaner, not that it will sound like shes gonna break in half
Old Aug 10, 2005 | 04:24 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLineDC2R &raquo;</TD></TR><TR><TD CLASS="quote">I dont know much about cams, so I want to ask the experts. I bought the itr with spoon cams and spoon cam gears, when Im driving on the freeway, the cams sounds so loud that like its gonna break, just want to know is that normal? </TD></TR></TABLE>
Could you please be a little more specific about exactly what it sounds like and where it's coming from?
Do you have an aftermarket ECU and the gears were used to tune on a dyno, or did the installer try to tune to known Spoon settings with a known ECU?
Was the valvetrain upgraded at the same time?
Did you buy a car from someone whom we'd know?
Adjustments could cause more valvetrain noise than normal, but remember that twincam Hondas have more valvetrain noise than a lot of cars, even other 16-valve twincam cars from other manufacturers.
It sounds like you are (forgive me) a relative novice, and I'd really counsel that you visit a local shop specialising in Hondas just to make sure you're not hearing anything radically wrong. The cams could be badly timed and the car would appear to drive normally, but at high speeds you could be causing some damage if they are that badly adjusted.
Old Aug 10, 2005 | 10:53 AM
ITR#465's Avatar
Default Re: spoon cams breaking? (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe need the valves adjusted?</TD></TR></TABLE>
I already done a valve adjustment few months ago
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
I am running a Spoon P73 ecu with stock valvetrain I believe, and haven't done any dyno tune yet
Old Aug 10, 2005 | 12:42 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLineDC2R &raquo;</TD></TR><TR><TD CLASS="quote">I am running a Spoon P73 ecu with stock valvetrain I believe, and haven't done any dyno tune yet</TD></TR></TABLE>
Are the cams just zeroed then, or what?
Old Aug 10, 2005 | 01:18 PM
Circuit Star-29's Avatar
LMAs?
Old Aug 10, 2005 | 06:08 PM
mugenracer's Avatar
I dont understand what you mean by saying the cams sound loud....how can you hear the cams. What type intake is on the car, as it (if aftermarket) will contribute to the noise more than anything, especially once in vtec.
I'm going to guess you mean engine noise and depending on your set up then once you have upgraded intake/header/exhaust etc etc then 95% of the time the engine noise is going to increase. The noise from my engine is loud as hell in vtec due to a short ram intake and apexi filter....but it doesnt mean somethings going to break or near breaking.
Old Aug 10, 2005 | 09:20 PM
Default Re: (mugenracer)
could be the injectors
could be the body in the trunk too...
Old Aug 10, 2005 | 09:36 PM
ITR#465's Avatar
i have aem cold air, dc header, when the rpm is around 3.5k and above , the engine starts to sound loud
Old Aug 11, 2005 | 09:22 AM
mugenracer's Avatar
thats sounds perfectly normal for the set up you have. A CAI is going to make more noise than the stock airbx because of its exposed filter.
ghg78
Nov 5, 2005 09:40 AM
boy_hapon
Aug 22, 2005 08:16 PM
95BlkGSR
Aug 21, 2004 04:29 PM
dElSleepiE
May 9, 2004 11:55 AM
EK MONEY
Nov 17, 2003 08:57 AM
