Si dizzy into an STD?
The dist. in my STD is bad and I have a spare CRX Si dist. that I was going to try and use. Is it possible to just de-pin the Si dist. and re-pin/re-wire the STD dist harness to use the Si dist, without worrying about MPFI bs?
Convert to MPFI or Sell your si dizzy.
Which reminds me. I just pulled my DX motor and can sell you the dizzy if you like. It worked fine when i pulled it.
Let me know if you're interested
P.S. Pretty sure its the same dizzy. My motor is a DPFI D15b2.
it will work, but u will have the two wires for the cyl sensor left over. but why would you want to sacrifice a perfectly good si dizzy when you can sell it and buy a much cheaper dx dizzy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef four door »</TD></TR><TR><TD CLASS="quote">it will work, but u will have the two wires for the cyl sensor left over. but why would you want to sacrifice a perfectly good si dizzy when you can sell it and buy a much cheaper dx dizzy?</TD></TR></TABLE>
i figured it would work...
I just didnt want to go through the hastle of selling it and then buying a new one. I just wanted to modify the one I already have. Im going to be coverting to MPFI at some point and going to be keeping the Si dist plugs to just re-wire it back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floored »</TD></TR><TR><TD CLASS="quote">I have a perfectly good dizzy out of a std if you want it. I converted to MPFI and no longer need it.</TD></TR></TABLE>
pm'd
pm'd
thedudefromjerz
Feb 15, 2008 09:48 AM
beatthisspeed69
13
May 5, 2007 01:34 PM
