JDM LSD Tranny
Old Aug 9, 2005 | 04:23 PM
MLBZ521's Avatar
Default JDM LSD Tranny
I have a JDM LSD Tranny to go in with my new motor and I was wondering if there is anything that I should changed on it before I do.
My grandfather said I should probably change the throw our bearing and fork and the seals/gaskets (Can't remember what he said now.) where the axles go in.
Should I do this and anything else? Also where can I get parts for a JDM LSD Tranny or can I use just normal H22 Tranny parts?
Old Aug 9, 2005 | 08:42 PM
MLBZ521's Avatar
Default Re: JDM LSD Tranny (MLBZ521)
Anyone know?
Old Aug 10, 2005 | 12:51 AM
BB6racer's Avatar
usdm release bearing and fork will work, and i don't think there are any seals where the axles go in, but i could be wrong...
Old Aug 10, 2005 | 05:17 AM
machine4321's Avatar
there is seals where the axels go in ..ive never had a problem but if you want piece of mind then do them
relase bearing is a must ..you wont need a new fork but grease the hell outta it and the relase bearing where it slides
Old Aug 10, 2005 | 06:47 AM
MLBZ521's Avatar
Default Re: (machine4321)
Thanks! You guys know about how much these cost? And the best place to get them? And even the part numbers? Or should I just go up to the dealership and get them from Honda?
I don't know what condition the seals are in, I need to go check the tranny, it's outside in a box.
Old Aug 10, 2005 | 06:54 AM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: (MLBZ521)
Are planning to put a new clutch in? because several aftermarket clutch companies provide the customer with a new throwout bearing with the purchase of a clutch.
Old Aug 10, 2005 | 03:00 PM
MLBZ521's Avatar
Yea, I putting in a new clutch, dÃ*dn't know that.. I'll check and see if mine came with one, don't remember that.. Thanks for the info though.
Old Aug 10, 2005 | 09:09 PM
MLBZ521's Avatar
Sweet, the clutch kit did come with the bearing.
I'll go check my tranny for the seals tomorrow since it's late, everyone's asleep, and it's in the garage in a rubber maid tub with stuff probably piled onto of it.....
Also what kind of gease should I use??
Thanks!
ozarkbw
Sep 4, 2024 08:18 AM
miyagi
May 15, 2006 09:14 AM
ramz7887
Nov 9, 2005 03:33 PM
deesracer
Jul 14, 2004 04:02 AM
