garrett t3 off of a sabb
Old Aug 9, 2005 | 03:52 PM
hcivic99's Avatar
Default garrett t3 off of a sabb
hey i just aquiard a garrett t3 off of a 89 sabb i noticed there are two looks like oil inlet and outlet flanfes, but there are two more looks like a threaded pipe i guess for water?? do i have to cool this turbo on my honda bothways or can i block off the water and use the oil alone? Also i took the compresser off today to clean and i noticed a thin black looks like a gasket but that was flaking off does that need to be replaced before i put the turbo on and if so were would i go about buying one? thanks for the help1
Old Aug 9, 2005 | 03:56 PM
N20civicB18's Avatar
Default Re: garrett t3 off of a sabb (hcivic99)
no need to block of the water ports if your not going to use them. there is a little gasket on the compressor housing, I usally dont replace it but somepeople use a little gasket maker.
Old Aug 9, 2005 | 04:18 PM
hcivic99's Avatar
Default Re: garrett t3 off of a sabb (N20civicB18)
thanks that is what i needed to know
Synapse Motorsport
Welding / Fabrication
24
Aug 3, 2007 09:58 AM
delslo93
Jan 2, 2005 09:42 AM
BoostedEX
Jul 1, 2004 12:59 PM
Scott - 93HB Si
Sep 6, 2002 08:05 AM
