prelude 4x114 conversion on eg?
Old Aug 9, 2005 | 03:31 PM
Nikoli's Avatar
Default prelude 4x114 conversion on eg?
is it possible?
Old Aug 9, 2005 | 03:32 PM
Russ713's Avatar
dAng!
Default Re: prelude 4x114 conversion on eg? (N)
yes
Old Aug 9, 2005 | 04:44 PM
Nikoli's Avatar
Default Re: prelude 4x114 conversion on eg? (Russ713)
i was just under there looking at them both and couldnt seem to figure out. is there a write or could you tell me how to do it?
Old Aug 10, 2005 | 07:43 AM
Redstone_Motors's Avatar
i doubt the prelude front knuckles will fit on an EG since they are about .5-.75" taller. the rear prelude brakes are a completly different design than the EG Civic's.
If you want 4x114.3 brakes, just buy some 96 Spec Integra Type R brakes from the Japan, and they will bolt right into your car. They have 10.2" front and 9.2" rear brakes, exactly the same size as 94-01 GSR's.
If you want to upgrade the front to 11", buy some Prelude VTEC (92-96) 11" front rotors, and get some 97+ Integra Type R or Prelude brake calipers and Brackets (26T is the correct one). This should all bolt in place without shaving or spacing.
Mojojojojo
Dec 9, 2016 04:27 PM
eg6madness
Suspension & Brakes
Apr 22, 2012 11:26 AM
Powelly
Oct 11, 2007 09:33 AM
Powelly
Oct 11, 2007 04:59 AM
