Bump Strips
Old Aug 9, 2005 | 02:16 PM
Alibi86's Avatar
Default Bump Strips
I was wondering how easy it is to remove the side bump strips without damaging my paint. I want to take them off so i can paint them. How are they held on and how easy would they be to remove/put back on?
Old Aug 11, 2005 | 07:29 AM
Duane_in_Japan's Avatar
Default Re: Bump Strips (Alibi86)
They are held on with more or less very good two sided tape, you can just peel them off. You will need a special compound wheel made by 3M for your drill. It is about 4 inch in diameter and it is like a big white eraser for your drill. It clings to the sticky tape and at the same time it eats the eraser away too so you may need to buy a couple depending on how much work you need to do. It wont hurt your paint just watch out for the drill head.
Old Aug 11, 2005 | 10:20 AM
Alibi86's Avatar
Can i just rip them off by hand? and not worry bout the drill? I am going to put them back on anways.
Old Aug 11, 2005 | 10:27 AM
Eddiebx's Avatar
i would recommend heating them up and prying it up slowly with a heat gun, that will soften the tape
Old Aug 11, 2005 | 10:46 PM
Alibi86's Avatar
and what would u do to re apply them? what kind of adhesive?
Old Aug 12, 2005 | 05:48 AM
Default Re: (Alibi86)
Very good 3M double sided tape made for automotive stripping.
Old Aug 12, 2005 | 10:16 AM
Eddiebx's Avatar
yep, scrape off all the old adhesive, and apply an automotive grade 3m double face tape
Old Aug 12, 2005 | 10:48 AM
Alibi86's Avatar
Thanks
pxsx
Aug 2, 2008 06:30 AM
BiG_DeE
May 12, 2008 07:21 AM
Buktheng
Mar 6, 2005 11:17 PM
Pullig
Jan 15, 2005 12:32 AM
deviant1
Jun 30, 2004 04:20 AM
