CRAFTSMANS OR LICOLN MIG WELDER?
Old Aug 9, 2005 | 01:42 PM
eKb20Vtec's Avatar
Default CRAFTSMANS OR LICOLN MIG WELDER?
I WANT TO START LEARNING HOW TO WELD AND I WAS JUST WONDERING WHICH IS A BETTER WELDER TO SART OFF WITH? THEY ARE BOTH THE 350ISH PRICE RANGE...SORRY NO MODEL NUMBER
Modified by eKb20Vtec at 4:30 AM 8/10/2005
Old Aug 9, 2005 | 01:52 PM
accord387's Avatar
most people will recommend hobart welder for a starting welder (miller also). I have a lincoln that im learing with and have no complaints as of yet.
Old Aug 9, 2005 | 02:32 PM
fizic's Avatar
the Miller 135 is my first welder and its perfect.
Old Aug 9, 2005 | 05:28 PM
Engloid's Avatar
OG Fabricator
Default Re: (fizic)
Miller is my preferred brand, but I do keep money, function, utility, and other things in mind. therefore, if it were my money, I'd go with Hobart so that I'd get performance, function, quality, AND price!!
Old Aug 9, 2005 | 06:40 PM
blueoval557's Avatar
Default Re: (Engloid)
If I had to do it all over, Id also go with a Hobart. I do have the Lincoln 135 also and have no complaints at all.
Kyle
Old Aug 9, 2005 | 07:04 PM
eKb20Vtec's Avatar
Default Re: (blueoval557)
thank for all the fast replies.....
which model or series hobart would you guys recommend ?
Old Aug 9, 2005 | 07:28 PM
paulzy's Avatar
between those 2, I'd go with the lincoln. The craftsman is actually a rebadged Century. In my experience, the quality and customer service(just in case you will need it) is better with teh lincoln
Old Aug 9, 2005 | 07:32 PM
eKb20Vtec's Avatar
Default Re: (paul vang)
how does a lincoln sp135 with cart, tank, mask and wire sound for 450?
Old Aug 9, 2005 | 08:32 PM
parasonic's Avatar
Default Re: CRAFTSMANS OR LICOLN MIG WELDER? (eKb20Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eKb20Vtec &raquo;</TD></TR><TR><TD CLASS="quote">I WANT TO START LEARNING HOW TO WELD AND I WAS JUST WONDERING WHICH IS A BETTER WELDER TO SART OFF WITH? THEY ARE BOTH THE 350ISH PRICE RANGE...SORRY NO MODEL NUMBER
Modified by eKb20Vtec at 4:30 AM 8/10/2005</TD></TR></TABLE>Nein!! Hobart for the budget (or a used miller)
Old Aug 10, 2005 | 08:12 PM
dfoxengr's Avatar
Default Re: CRAFTSMANS OR LICOLN MIG WELDER? (parasonic)
miller 135 from the guy on ebay is the cheapest youll get from miller. awesome for what it is though.
Old Aug 12, 2005 | 10:57 AM
ecumatt's Avatar
Default Re: CRAFTSMANS OR LICOLN MIG WELDER? (dfoxengr)
some craftsman welders are mae by lincoln
Old Aug 12, 2005 | 12:58 PM
Engloid's Avatar
OG Fabricator
Default Re: CRAFTSMANS OR LICOLN MIG WELDER? (ecumatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecumatt &raquo;</TD></TR><TR><TD CLASS="quote">some craftsman welders are mae by lincoln</TD></TR></TABLE>
The Chevette and Corvette were both made by Chevy. That doesn't mean that the Chevette is nearly the car a Corvette is.... or even a Camaro.
Old Aug 13, 2005 | 05:57 PM
Datum1Engineering's Avatar
Default Re: CRAFTSMANS OR LICOLN MIG WELDER? (Engloid)
forget the craftsmans one.. lincoln is highly recommended.. so is miller.
i use lincoln mig, tig welding here for years and never had problem from starting learning tig to being a tig junkie ..
Old Aug 13, 2005 | 08:48 PM
blzn4whlr's Avatar
Default Re: CRAFTSMANS OR LICOLN MIG WELDER? (Datum1Engineering)
remember that hobart is a cheaper version of miller there for it has inferior parts on it, just look at the duty cycles on the two comparable models, personally i have had good experience with my shops lincoln machines but i have heard lots of rumors about them breaking down all the time, and i am pretty sure that lincoln makes some of the craftsman machines
Old Aug 14, 2005 | 07:14 AM
JCushing's Avatar
the new craftsman 135 amp welder they sell for $350 is made by clarke now. you can get it from clarke for about $270 bux from weldingdepot.com. you can also get it complete with a gas flowmeter/regulator that you need for true mig for $312
Old Aug 14, 2005 | 10:32 AM
ComputerJLT's Avatar
I have a lincoln Pro mig 175 (lowes equivilent of a SP175). It's great; 220v and has PLENTY of amps and i've yet to have a problem with the wire feed mechanism or anything like that.
It wound up being ~ $600 with tax but i got the welder; about 4 spools of mig aluminum and flux wire; a cart; and a nice bosch grinder with it
Old Aug 15, 2005 | 03:10 PM
eKb20Vtec's Avatar
Default Re: CRAFTSMANS OR LICOLN MIG WELDER? (ComputerJLT)
THANX FOR ALL THE INFO
TurboEM1
Acura TSX
12
Oct 3, 2008 12:01 PM
Nature's Renewal
Welding / Fabrication
Mar 15, 2006 07:44 PM
DIY_Racing
Feb 9, 2005 02:38 PM
rcurry14
Oct 12, 2004 07:35 PM
88turdbucket
Mar 23, 2004 10:53 PM
