bolting up jdm 4-1+ test pipe to mugen twin loop?
Old Feb 21, 2002 | 01:31 PM
mugenr#1011's Avatar
Default bolting up jdm 4-1+ test pipe to mugen twin loop?
soon im getting a jdm header and test pipe..i will be bolting it up to a mugen twin loop...does anyone know if i would have any problems with it fitting correctly....im getting this for$325 for both so i couldnt resist the offer..oh yeah the test pipe is the first gen godspeed(the one that has no problems)...thanks
Old Feb 21, 2002 | 02:13 PM
Default Re: bolting up jdm 4-1+ test pipe to mugen twin loop? (mugenr#1011)
uuuuuuuuuhhhhhhhh anyone??????
Old Feb 21, 2002 | 02:29 PM
JoshRambo's Avatar
i have the JDM 4-1 but got a carsound cat. no problems here
[Modified by Gravity, 6:29 PM 2/21/2002]
Old Feb 21, 2002 | 02:31 PM
Default Re: bolting up jdm 4-1+ test pipe to mugen twin loop? (Gravity)
thanks
Old Feb 21, 2002 | 02:58 PM
BABY NSX's Avatar
There are two versions of the Twin Loop B-pipe. The USDM version has the same restriction as the USDM stock exhaust where it bolts up to the cat.
The JDM version is a full 60mm pipe from resonator to the cat with no restrictions. I am currently modifying my USDM twin loop to JDM spec and increasing the flange size to a full 2-1/2" where the cat and B-Pipe come together.
I'm not sure how Dan made his test pipes but if it was designed to bolt up to the stock USDM B-pipe then you should be fine but you will have restrictions still in your exhaust.
Regards,
rhys.l
Sep 6, 2012 02:32 PM
Kruzer
Mar 13, 2011 08:31 PM
Justimo
Mar 23, 2010 06:20 PM
Bbasso
Dec 14, 2003 03:34 PM
mugenracer
Aug 2, 2002 06:51 PM
