Taking electronics out before welding the tub in car?
Old Aug 9, 2005 | 01:26 PM
HondaJon's Avatar
Default Taking electronics out before welding the tub in car?
My uncle, who does some welding on his spec Ford racer, has offered to weld shut the drill holes that I have left in my tub after removing my 4 point, Sparco buckets, and harnesses, all of which were welded through the floor.
Do we need to remove the ECU, alternator, or anything else before striking a weld on the tub? My uncle seemed slightly concerned about the charges involved and possibly frying some electronics?
Any input/experience would be greatly appreciated....
Jon
Old Aug 9, 2005 | 06:44 PM
blueoval557's Avatar
Default Re: Taking electronics out before welding the tub in car? (HondaJon)
Most will say disconnect the battery. I have never had any problems without disconnecting the battery, but I do take the extra precaution now. Just disconnect the battery and you'll be fine.
GOOD LUCK!
Kyle
Old Aug 9, 2005 | 07:03 PM
2k.civic.si's Avatar
Default Re: Taking electronics out before welding the tub in car? (blueoval557)
wont hurt a thing....weld away
Old Aug 9, 2005 | 07:36 PM
tony1's Avatar
I usually unplug any expensive electronics for safetys sake. If you have a good ground on the chassis then you should be fine, but better safe than sorry. It only takes a min. to unplug the ecu.
salandrew09
Welding / Fabrication
Oct 22, 2010 04:55 PM
eMpAtHy
Aug 7, 2010 03:28 PM
redDAinteg
Apr 16, 2009 07:14 PM
cr_rex
Jan 11, 2006 08:07 AM
SoSlo
Jun 3, 2005 10:07 PM
