TRANNY LEAK FIXED!!! READ HOW!! L@@K!! YAY!!! YAY!-FINALLY!!!!!
Ok, after 2 autozone seals, and 2 oem honda seals all hope was lost. THIS TIME...... I put the final honda seal in again, (and I had a little trouble getting it perfectly seated)..anyway i put a product called "LOCKTITE" -something like that all around the outter edge of the seal. Let me remind you that the seal was not even on there perfectly smooth and even, I didnt wanna jack it up since it was hard to move it around once in there. ANYWAY, i put that locktite stuff around it (its like a silicone that turns into a gasket (heat proof))...and I have been driving all over, in all conditions and all bumpes and NO LEAK!!! Let me say it again, NO LEAK!! I have had this problem for months and begged and pleaded for answers and nobody seemed to have the answer..I STRONGLY urge you to try this product if you have a constant leak from you tranny axle seal and cant figure out how or why. Man it feels good to have all your fluids staying where they belong....I HOPE THIS HELPS ANYONE ELSE WHO WAS AS DESPERATE AS I WAS ABOUT THIS SITUATION!!!
Also, before I did this I was thinking about bringing the car to Acura where they would do it for $200 and warranty it for 12 months, but then I heard that if the seal was to go bad again, they would say something else caused it (like an axle rubbing on it) and therefor it wouldnt be covered. SO, like I said I would do this what I did and so far so good, if it would happen to leak again, I would just do the same thing now that THERE IS A SOLUTION-THANK YOU JESUS (always helps me)!
