intake/battery relocating
Old Aug 9, 2005 | 01:19 PM
Bjorn20's Avatar
Default intake/battery relocating
alright guys. i just installed some off brand ram air intake on my 91 std hatch. 1 problem though, it doesnt clear the battery. so i took the battery out and was thinking of doing the relocating the battery to the hatch. but ive ran into a couple problems with 15 different stores telling me different things.
(welding shop) they had 1 guage wire, and said it would be a huge fire hazard running cable to the back to supply the battery with power, and would give too much resistance or some bs and wouldnt fire up the battery
(wellie auto) they said it wouldnt be a fire hazard at all, completely comon to relocate the battery. and recommended me buying a $100 kit for it that comes with everything i guess. or they said to get longer piping so it would clear the battery.
(exhaust pros) they said they could install it for me, but hes like talking about cold air intake and said something about water getting under the hood and messing **** up. but i have ram intake, wtf does that have to do with water???
and i dun see wuts so ******* complicating about this. if i relocate the battery, ill need a positive and ground/negative cable with terminals running through the passenger side firewall and plugging into something that i havent gotten that far yet lol. OR, i could possibly get a smaller sized battery that the intake piping would clear, but then im worried about hood clearance. OR i could get longer piping and it would clear the battery. but id much rather just get the ******* battery out of there. and as u can see im kinda confused on this since ive gotten 15 different answers on wut im trying to do.. my main question would be how thick (gauge) of cabling would i need. terminals, where does the **** hook up to under the hood????
also where the hell do i find this 20 feet of cable??
thx guys im really confused, so any help for a noob would be cool
Old Aug 9, 2005 | 01:36 PM
vegaskurt's Avatar
Default Re: intake/battery relocating (Bjorn20)
How about this for easy. Get a smaller battery.
http://www.portablepower.com/i...105S6
BTW, are you putting this air intake on a dpfi setup? If so then yeah it wont fit right and it will give you no gain in power. When you go to mpfi it makes a huge difference and the intakes will fit.
Old Aug 9, 2005 | 01:39 PM
TheBobFather's Avatar
Default Re: intake/battery relocating (vegaskurt)
One word.......traction. What good is it if all the weight is in the rear.
Old Aug 9, 2005 | 01:42 PM
Bjorn20's Avatar
wut does an intake have to do with fuel delivery??
and i dun wanna spend $100 on a battery... im trying to make this a cheap project... not really even a project but anyway, thx for ur advice
any other ideas here?
Old Aug 9, 2005 | 01:54 PM
LoneStarCRX's Avatar
Battery Relocation
Old Aug 9, 2005 | 01:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">How about this for easy. Get a smaller battery.
A little cheaper at Battery Mart
Old Aug 9, 2005 | 02:31 PM
JDM Panda's Avatar
Default Re: intake/battery relocating (dewarcr)
lol... Did you just say.. "what good does a battery do in the back" It allows for...trubo pipeing....intakes...and if you car is off balance on the scales... then it helps the balance... why ask such a dumb question? lol its a sohc...traction isnt a issuse...jesus...
The reason you need to worry about the size of wire is because they'll melt if there not the right size (not sure what kind of wire they use). Do a search.
Old Aug 9, 2005 | 02:38 PM
Bjorn20's Avatar
Default Re: intake/battery relocating (JDM Panda)
well i cracked open the box that the positive wires are going to, and it doesnt look very big at all, id say its maybe 6 guage at the biggest. but um heres another question.... how am i mounting this to my car. yes ive heard drilling holes into the frame. but wut am i doing with those holes?? im not going out and spending $100 on a kit for it. wut did u guys use to hold down the battery, that doesnt costs $50
thx
Old Aug 9, 2005 | 02:39 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Panda &raquo;</TD></TR><TR><TD CLASS="quote">if you car is off balance on the scales... then it helps the balance</TD></TR></TABLE>
Ding ding! Winn3r! Moving 30 lbs from one corner to another isn't going to turn it into a tire-destroying machine, but it will cure a corner weight issue very effectively.
And for gods sake use a fuse or circuit breaker. Your car WILL burn to the ground if you don't.
Old Aug 9, 2005 | 02:51 PM
JDM Panda's Avatar
Default Re: intake/battery relocating (drdisco69)
i know you have to have 1 hole that goes to outside the car for fumes. like i said do a search.. tehres been about a billion topics on this
Old Aug 10, 2005 | 09:47 AM
vegaskurt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">wut does an intake have to do with fuel delivery??</TD></TR></TABLE>
Thats a silly thing to say...
But to clarify, if you are DPFI, the intake is in a different spot compared to the mpfi. I know cause I put my ebay intake on my dpfi manifold and had hood/battery clearance issues. When I went mpfi, it fit like a glove.
Old Aug 10, 2005 | 11:15 AM
Bjorn20's Avatar
know cause I put my ebay intake on my dpfi manifold and had hood/battery clearance issues.</TD></TR></TABLE>
that would be the hole point of why i posted this topic
Old Aug 10, 2005 | 11:33 AM
SiMateoAko's Avatar
There is an article on http://www.fourthgenhatch.com about this, but the site isn't working for me right now. I've found that site to be very informative and easy to understand.
Old Aug 11, 2005 | 07:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Panda &raquo;</TD></TR><TR><TD CLASS="quote">lol... Did you just say.. "what good does a battery do in the back" It allows for...trubo pipeing....intakes...and if you car is off balance on the scales... then it helps the balance... why ask such a dumb question? lol its a sohc...traction isnt a issuse...jesus...
The reason you need to worry about the size of wire is because they'll melt if there not the right size (not sure what kind of wire they use). Do a search.</TD></TR></TABLE>
Whoa buddy slow down. I meant this for drag racing. Not track. And if you cant find room up front with the battery there, then you shouldnt be working on cars. Especially with a sohc. I have a turbo b16 with 2 1/2in charge pipes with the battery in stock location. F-ing cake. Besides, longer wire = loss in power. If you have the right set up( wheels, tires, suspention) any EF will handle like its on rails.
You come here to flame, only to be hipicritical, and give lowsy advise. I feel sorry for you
Old Aug 11, 2005 | 07:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Panda &raquo;</TD></TR><TR><TD CLASS="quote">i know you have to have 1 hole that goes to outside the car for fumes. like i said do a search.. tehres been about a billion topics on this</TD></TR></TABLE>
Boy you sure learned alot in the 4 months youve been a member. Go search for another site to post your BS..................lol
Old Aug 11, 2005 | 10:19 PM
JDM Panda's Avatar
Default Re: intake/battery relocating (jnbhonda)
..... your the 1 giving me **** for trying to help you.. and you say wow ive learnd a whole lot in 4 months.. why would you post such a lame thread .. go look up a search...and in a kit there is a vent tube the runs from the box the battery sits in to out side the car...
chase7687
Mar 30, 2009 03:34 AM
KDvtec5757
Jun 12, 2008 09:32 PM
aaronhume
16
Oct 27, 2005 12:29 AM
JDM_NA_eg6
27
Dec 1, 2004 08:30 AM
serious
Oct 3, 2002 11:02 AM
