spark plug wires keep poping off
Old Aug 9, 2005 | 11:45 AM
allmotorteg_96's Avatar
Default spark plug wires keep poping off
like the title says they keep poping off of the dizzy what would cause/fix this
Old Aug 9, 2005 | 11:46 AM
PLAGUED_DB7's Avatar
Default Re: spark plug wires keep poping off (allmotorteg_96)
spread the middle prong so it fits tighter...maybe time for a new set of wires????
Old Aug 9, 2005 | 11:48 AM
Default Re: spark plug wires keep poping off (PLAGUED_DB7)
do you mean tighten the ends of the wires
Old Aug 9, 2005 | 11:50 AM
no spread them out so that they are more oval that circle. then jam then in there carefully and they wont pop off no more..
Old Aug 9, 2005 | 11:56 AM
ok i will try this
thanks bill
94lsboost's Avatar
after you slide them on and they lock, tighten a zip-strip around the rubber boot onto the shank of the dizzy. Engine vibration can loosen those style of wire connections, zip strips are always a good idea!
Old Aug 9, 2005 | 12:22 PM
Default Re: spark plug wires keep poping off (94lsboost)
If he spreads the prong a bit they will 'snap' when put into the dizzy, and zip ties wont be nessasary at all. I would be afraid that they would melt. I use aip ties on body/ non engine areas...
Old Aug 9, 2005 | 12:30 PM
94lsboost's Avatar
I use them.. I snap mine on, as well as zip tie... just a precaution. I haven't melted one yet, you'd be surprised what those bastards can take.
Old Aug 9, 2005 | 02:39 PM
thanks for the info guys
Old Aug 9, 2005 | 02:45 PM
jdmotorsports's Avatar
the zipties work. also make sure they are a good set of wires and cap. the 2 should 'snap' toghter.
shadow29485
May 22, 2007 08:20 PM
jsrusse11
10
Nov 7, 2005 05:20 PM
89civichatchback
Jul 13, 2003 01:35 AM
wannakno
Nov 26, 2002 08:32 PM
Wazup
Nov 11, 2002 01:15 AM
