Replacing Speedometer cable
Old Aug 9, 2005 | 10:19 AM
JKingCivicSi's Avatar
Default Replacing Speedometer cable
Is there an easier way to get at where the speedo cable plugs into the gauge cluster than from below? I can't reach the point where it plugs in. could I reach it if I took the cover off the back of the console?
Old Aug 9, 2005 | 10:27 AM
mahatma's Avatar
Default Re: Replacing Speedometer cable (JKingCivicSi)
Yep if you take the cover you can gain access. It's tight, but that's how I've always done it.
Old Aug 9, 2005 | 10:41 AM
Default Re: Replacing Speedometer cable (mahatma)
How does that cover come off? It has no screws. Do I just pry it off?
Old Aug 9, 2005 | 10:44 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The cluster cover has two removable pieces that conceal
the screws..
Look through the winshield at the cover and you will see them..
Also see: https://honda-tech.com/zerothread?id=1325930
C_H_A_D
Jul 6, 2008 07:42 PM
peanut butter
Feb 18, 2008 04:00 PM
cutt
Nov 12, 2004 06:57 PM
loid
Jul 26, 2004 08:33 AM
