b18b eg....need help with a/c....
Old Aug 9, 2005 | 10:14 AM
JDM RHD eg6's Avatar
Default b18b eg....need help with a/c....
yo whats up guys...
well i swaped in a 96 LS motor in my 92 hatch and i need to know what a/c lines do i need to use for a eg with a b18b swap...thanks
Old Aug 9, 2005 | 10:31 AM
R1_Owner's Avatar
Default Re: b18b eg....need help with a/c.... (MrEF8)
Hasport has an adapter bracket that will allow you to use the ac compressor off of your stock D motor and all of those lines. That way, you dont have to mod the lines or get custom ones. I think it is $170 or something like that.
Old Aug 9, 2005 | 10:36 AM
Default Re: b18b eg....need help with a/c.... (R1_Owner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R1_Owner &raquo;</TD></TR><TR><TD CLASS="quote">Hasport has an adapter bracket that will allow you to use the ac compressor off of your stock D motor and all of those lines. That way, you dont have to mod the lines or get custom ones. I think it is $170 or something like that.</TD></TR></TABLE>
o thanks alot... but i dont even have the stock a/c line....$170 is to much for brackets...
Old Aug 9, 2005 | 11:09 AM
bostoncal's Avatar
go to a junkyard and get AC lines...i believe at least 2 bolts will hold up your D series bracket into the b18b...or you can always go with the DOHC VTEC Del Sol AC bracket.
Old Aug 9, 2005 | 11:31 AM
Default Re: b18b eg....need help with a/c.... (Este_Cara)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Este_Cara &raquo;</TD></TR><TR><TD CLASS="quote">go to a junkyard and get AC lines...i believe at least 2 bolts will hold up your D series bracket into the b18b...or you can always go with the DOHC VTEC Del Sol AC bracket.</TD></TR></TABLE>
what a/c lines shoud i buy?
hondab1015
Jun 26, 2015 07:46 AM
mikester1222
Oct 29, 2007 06:10 PM
racer_X_123
Jun 30, 2006 08:25 PM
BlKdOutEk
Aug 12, 2005 09:54 AM
Sohc Driver
Jul 31, 2003 03:36 PM
