squeaking brake....
Old Feb 21, 2002 | 01:00 PM
KLN's Avatar
KLN
Default squeaking brake....
i drive a 94 integra and my rear driverside brake squeaks when drive...i recently went to the tracks, do you think that is why it is squeaking?...i didn't know about cooling brakes and stuff, so after every run i just parked the car... the rear brake only squeaks when i drive...it stops when i am braking...
do you think it is a warped rotor? they are stock rotors by the way
Old Feb 21, 2002 | 02:38 PM
3rdGteg's Avatar
Default Re: squeaking brake.... (KLN)
Hey, let me know when u find out what it is because I started having the same problem also after I ran my integra at the tracks. I think it could be a messed up caliper that keeps on sticking to my rotor cuz I run out of brake pads pretty quick.
Old Feb 21, 2002 | 04:05 PM
Urban Business
Guest
Posts: n/a
the problem most likely lies in the pads. check them out. look for unuaul ware. if you warped yur rotor (heat) replace that. if pads look unually worn replace them
Old Feb 21, 2002 | 04:25 PM
gtracer's Avatar
worn rotors! how old are they? sometimes pads cause the sound but I think it's because of the rotors (my pug has the same problem). I don't know how to stop it though. For the next pad change you may try different pads or just try to live with it
Romo Pyro
Nov 15, 2010 05:31 PM
seer_claw
Feb 24, 2004 08:13 PM
acuraLSSE95
Jul 28, 2003 06:39 AM
976
Jun 6, 2002 06:12 PM
