more than one way to get a specific CR which is best
Old Aug 9, 2005 | 09:59 AM
xDicktonesx's Avatar
Default more than one way to get a specific CR which is best
from what i understand a b16 block with PCT pistons and a pr3 head will yeild around about an 11.4:1 CR. that same bllock and head with p30s wit hthe head milled .030 will yield almost the same CR. is any one of the 2 desireable. does it make absolutely no difference how you get the CR you want?
also...how much would one need to mill a pr3 head if they used ITR pistons in that setup to get to 11.8:1?
id ratehr use OE honda stuff than turn to an aftermarket piston manufaturer especially since i can get the rings with the pistons and itll all be honda.
Old Aug 9, 2005 | 10:14 AM
Black R's Avatar
25 Year Member
Default Re: more than one way to get a specific CR which is best (CRXofPain)
.....if you can get the c/r you desire without milling or decking, then that is preferable. There is more room for clearance between the pistons and valve - and this is good when you have bigger cams, which like higher compression.....
Old Aug 9, 2005 | 10:33 AM
Default Re: more than one way to get a specific CR which is best (Black R)
i think i heard differently form mike sarr who heard from omni man. yea. weird. he used p30s in his build. he milled .030 and had the pistons modified for clearance. im basically just wondering why he did that as apposed to just using CTR. its looking like ill leave my head alone as far as the mill and just use the PCT pistons and rings. maybe omni can chime in. my dvd is on its way to iraq. cant wait.
Old Aug 9, 2005 | 10:54 AM
slofu's Avatar
PCT slugs are heavier, and more weight is located above the pin, which, iirc, is located a bit lower in the piston than on the other B slugs. so, there's more weight to move, and possibly a greater moment arm, which means more leverage on the skirts, and more friction.
what you want is the best quench; if you can get the same compression with less surface area in the chamber (including piston domes), you'll get a a faster, more complete burn, and reduce the chance of detonation.
Old Aug 9, 2005 | 10:57 AM
Used2beAb16's Avatar
Default Re: more than one way to get a specific CR which is best (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">PCT slugs are heavier, and more weight is located above the pin, which, iirc, is located a bit lower in the piston than on the other B slugs. so, there's more weight to move, and possibly a greater moment arm, which means more leverage on the skirts, and more friction.
what you want is the best quench; if you can get the same compression with less surface area in the chamber (including piston domes), you'll get a a faster, more complete burn, and reduce the chance of detonation. </TD></TR></TABLE>
what he said
ben_art
13
Dec 2, 2014 03:09 PM
EG6Boy702
Apr 23, 2009 11:10 AM
xDicktonesx
Dec 26, 2005 05:50 AM
hondaluva
11
Apr 26, 2005 07:27 PM
Integra91LS
Mar 30, 2002 08:49 PM
