Throttle body coolant bypass question
Old Aug 9, 2005 | 07:58 AM
MKIIISupra's Avatar
Default Throttle body coolant bypass question
I want to block off the coolant lines that run through the throttle body. From what I can see a line runs from under the intake into the TB. Then it comes out of the TB and goes into a thing on the back of the intake. Then a line runs somewhere else out of the "thing". I was wondering, do I just block off the TB or the thing that is bolted to the back of the intake as well? I hope you guys can make sense of this, thanks!
Old Aug 9, 2005 | 08:14 AM
MKIIISupra's Avatar
Default Re: Throttle body coolant bypass question (MKIIISupra)
I guess I should mention its a D15
Old Aug 9, 2005 | 08:18 AM
Relic1's Avatar
disconnect the two hoses from the TB, connect them together. plug the TB ports with vacuum plugs.
dougshatch
68
Jul 12, 2023 06:24 AM
ls_bitik
Jan 4, 2008 03:31 PM
4DRmafia
Sep 3, 2005 10:17 AM
philly-O
May 25, 2004 04:56 AM
Wiseguy619
Nov 28, 2003 03:28 PM
