Timing for LS/VTEC w/9:1 CR
Old Aug 9, 2005 | 05:39 AM
LST2's Avatar
Default Timing for LS/VTEC w/9:1 CR
I am working on the timing in boost for my 85mm LS/VTEC 9:1 CR with a T3/T67 using uberdata. Should I start with the GSR or the LS timing map? The basemap for the GSR is at 22* and the LS is 28*. I would imagine that the CR has a lot to do with it and my 9.0 is closer to the LS. However, most people say to start with the GSR basemap. Any suggestions?
Old Aug 9, 2005 | 06:40 AM
boosted k20's Avatar
Default Re: Timing for LS/VTEC w/9:1 CR (LST2)
um, u have VTEC so u use GSR maps and timing on the GSR is also 28* on the high cam ignition map
Old Aug 9, 2005 | 06:50 AM
LST2's Avatar
Default Re: Timing for LS/VTEC w/9:1 CR (boosted k20)
Duh... good point. I am tuning my low cams now... did not even look at the high cams yet. Thanks for pointing that out. Much clearer now.
jose12889
Apr 29, 2012 08:03 AM
BlueShadow
Aug 31, 2005 12:37 PM
DTAYLOR
Aug 15, 2002 08:37 AM
