best oil to use for ls turbo
Old Aug 8, 2005 | 11:25 PM
Dr Miller's Avatar
Default best oil to use for ls turbo
need to change the oil asap, what should i buy?
Old Aug 9, 2005 | 12:41 AM
IntegraBoy04's Avatar
Default Re: best oil to use for ls turbo (Dr Miller)
I use Castrol GTX 10w30.
Old Aug 9, 2005 | 02:28 AM
hondaguyef's Avatar
Default Re: best oil to use for ls turbo (IntegraBoy04)
Mobil1 10w-30 all year
Old Aug 9, 2005 | 05:40 AM
s2kdre's Avatar
Default Re: best oil to use for ls turbo (hondaguyef)
mobil 1 is a waste if ur gonna change it every 1k miles, i just use valvoline 10w30
Old Aug 9, 2005 | 05:42 AM
musclefella's Avatar
Default Re: best oil to use for ls turbo (jdmhonda)
Duckhams 10w 40 semi synth
Old Aug 9, 2005 | 06:13 AM
blackeg's Avatar
Default Re: best oil to use for ls turbo (musclefella)
i use castrol gtx 10w-40. my car burns oil though, so for every oil change i use maybe 1/2 quart of lucas heavy duty oil stabilizer.
Old Aug 9, 2005 | 07:39 AM
baybee_boy's Avatar
for anyone that has the money for a turbo, I would highly recomend using mobil 1 full synthetic. Most integras call for 5w30. Use that but put a quart of engine lucas in with it. It is a oil stabilizer that bonds to engine parts. Not like slick 50 BS but it works good. Will boost your oil pressure up a little bit and will run smoother. Garauntee!!!
Old Aug 9, 2005 | 09:35 AM
Default Re: best oil to use for ls turbo (baybee_boy)
I think Synthetic is too thin to use on a boosted car..since it is already so thin.
Old Aug 9, 2005 | 09:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I think Synthetic is too thin to use on a boosted car..since it is already so thin.</TD></TR></TABLE>
i've been running semi synthetic on all my builds.
Old Aug 9, 2005 | 10:49 AM
SlowB16si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Mobil1 10w-30 all year </TD></TR></TABLE>
Old Aug 9, 2005 | 12:04 PM
hondaguyef's Avatar
I'd love to hear the educated information to back this statement up.
Phil
Old Aug 9, 2005 | 01:37 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I think</TD></TR></TABLE>
synthetic is supposed to be more superior to conventional for high tems and breakdown. it is true if you take 2 differnt brand oils of same rated visc., their actual specs could vary but doesn't say anything about synthetic being thinner. nothing wrong with conventional but if you want a wide range multi visc oil like 15w50 or 5w40 (at least i coudln't find any conventional in that weight) you just have to go with synthetic.
Old Aug 9, 2005 | 01:39 PM
civicLX92's Avatar
so how often do you have to change oil on a turbo car? i know it runs under a hell of a lot more stress, i just want to know how often you to change at 5, 10, and about 15 psi..
Old Aug 9, 2005 | 02:31 PM
hondaguyef's Avatar
Default Re: best oil to use for ls turbo (civicLX92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicLX92 &raquo;</TD></TR><TR><TD CLASS="quote">so how often do you have to change oil on a turbo car? i know it runs under a hell of a lot more stress, i just want to know how often you to change at 5, 10, and about 15 psi..</TD></TR></TABLE>
I change mine after every track day or every 2k mi. Usually it gets changed before the 2K mi. mark though due to visits to the track. I'll never use Conventional oil again. First motor I ever used it in(other than break in) spun a rod bearing. I'm not blaming it directly on the oil but, the $2K+ mistake wasn't worth the few dollars I saved and peace of mind I lost.
Phil
Old Aug 9, 2005 | 02:37 PM
Sohc Driver's Avatar
mobil1 10w30 here... Been boosted for a year now
Old Aug 9, 2005 | 05:50 PM
ProjectDarkBlack's Avatar
Default Re: best oil to use for ls turbo (Sohc Driver)
the general rule is 2000k miles with <U>full</U> synthetic all the time and you are golden.
Old Aug 9, 2005 | 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I think Synthetic is too thin to use on a boosted car..since it is already so thin.</TD></TR></TABLE> you should never run conventional oil unless you have a water cooled bearing section, even then it is still recomended. Oil passes through the bearing section that is 400+ degrees, conventional breaks down into a laquer film and cokes up your bearings much easier as it breaks down around 225* and synthetic is much better at ~275*
Old Aug 9, 2005 | 06:08 PM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I use Castrol GTX 10w30.</TD></TR></TABLE>
Same here.
I change my oil so much, there is no point in going to synthetic. If I had a $1,000+ ball bearing turbo, it might be a different story though...
Old Aug 9, 2005 | 07:46 PM
mike93eh
Guest
Posts: n/a
mobile 1 10w30 &gt; *
Old Aug 9, 2005 | 07:49 PM
epic1si's Avatar
i use royal purple 10w30 every 3k miles.
Old Aug 9, 2005 | 09:05 PM
Dr Miller's Avatar
well, looks like like the lst is gettin a mobil1 10w30 meal tomorrow. however, i have heard good things about royal purple.. but i can't find it anywhere. thanks for the info guys, i really appreciate it.
Old Aug 9, 2005 | 10:04 PM
Default Re: best oil to use for ls turbo (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">
Same here.
I change my oil so much, there is no point in going to synthetic. If I had a $1,000+ ball bearing turbo, it might be a different story though...</TD></TR></TABLE>
changing your oil a lot is not going to keep if from breaking down inside your turbo
Old Aug 9, 2005 | 10:39 PM
Default Re: best oil to use for ls turbo (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">
changing your oil a lot is not going to keep if from breaking down inside your turbo </TD></TR></TABLE>
Regular oil won't break down that fast. Just because synthetic oil is better, doesn't mean regular oil is useless. I change my oil every 1000 miles, give or take a few, so regular Castrol GTX 10w30 will work fine. I'm sure if I had synthetic oil I could go twice as long or maybe even a little longer between oil cahnges, but I drive a honda, not a race car...
Old Aug 9, 2005 | 10:49 PM
H22 CD5's Avatar
i was using mobil1 10w30 full syn. but i just switched over to 15w50 due to the higher summertime temperatures. is there anything wrong by doing this?
Old Aug 10, 2005 | 04:55 AM
9341civic's Avatar
Default Re: (H22 CD5)
i use royal purple 15w40
