Need Help ASAP...lower front left control arm bar
Old Feb 21, 2002 | 11:07 AM
RTW DC2R's Avatar
Default Need Help ASAP...lower front left control arm bar
Today I had my front left suspension checked out on my 2000 ITR because the camber is obviously not right and something is bent. The car was in an accident before I got it, and you can tell just by looking at it. So I had an alighnment/frame shop take a look today. They told me that the lower front left control arm bar is bent and should be replaced, the frame is kinda beat up but nearly back to spec, and it can probably be fixed with just a new control arm bar and a camber adjustment....
now, will ANY 2000 integra control arm bar fit? or are they ITR specific and not interchangeable? The obvious reason I need to know this is because I would rather get a used bar from a salvage place rather than get a brand new bar. If I have to go with a new bar, any idea how much they run?
Thanks in advance.
Old Feb 21, 2002 | 11:10 AM
sgT's Avatar
sgT
Default Re: Need Help ASAP...lower front left control arm bar (12secTypeR)
The bushings should be different for ITR so its best to get one from an itr.
Old Feb 21, 2002 | 11:12 AM
Mike K's Avatar
Default Re: Need Help ASAP...lower front left control arm bar (sgT)
All 94+ Integra front LCAs are the same part number.
The hard bushings are the same, but the large rear bushing is different.
Old Feb 21, 2002 | 11:16 AM
RTW DC2R's Avatar
would i even notice the difference in the bushings??
Old Feb 21, 2002 | 11:46 AM
RTW DC2R's Avatar
Default Re: Need Help ASAP...lower front left control arm bar (Mike K)
would you recommend NOT going with a regular Integra LCA? are the size of the bushings different or just the hardness?
Rand The Man
Jul 7, 2010 01:53 AM
dc2leftovers
Jul 24, 2009 12:27 PM
rca90gsx
Feb 14, 2007 12:19 PM
heygotboost
Jul 28, 2004 07:18 PM
