Brake lines non-ITR vs ITR
Just curious what differs because I'm running ITR LCAs and looking to order some stainless lines... are there different brackets or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Ricer »</TD></TR><TR><TD CLASS="quote">Nope. Same. If you need Lines let me know as I sell earl's lines.</TD></TR></TABLE>
Good info, thanks.
Good info, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">woof woof</TD></TR></TABLE>
Takumi!!!!
Takumi!!!!
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Is there a difference in length between GSR front brake lines and ITR front lines? I ask because I am planning on putting ITR front calipers on my GSR.
Thanks!
Thanks!
Do the earl's have that clear plastic tube covering like the stoptech lines? Better some protection than none... my car does double duty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 »</TD></TR><TR><TD CLASS="quote">Is there a difference in length between GSR front brake lines and ITR front lines? I ask because I am planning on putting ITR front calipers on my GSR.
Thanks!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">
Do the earl's have that clear plastic tube covering like the stoptech lines? Better some protection than none... my car does double duty.</TD></TR></TABLE>
Lines are the same length. Earl's lines do not have a plastic covering it...I run the Earl's lines. No problems at all.
I have Gsr/Sir lines on my eg with type r brake swap, I'm pretty sure they are earls, and they are tight, not proper, you need itr, the rotors push out the calipers further and you need the itr ones, They will fit but it's stretching it. I plan on selling mine over the winter to get the proper ones in. Rear are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
Takumi!!!!
You know what, those would work great as those sleeping eye cover things! They would probably influence some of your dreams too.
Takumi!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology »</TD></TR><TR><TD CLASS="quote">
That looks like some WEIRD SCIENCE thing right there with the dog!
</TD></TR></TABLE>That looks like some WEIRD SCIENCE thing right there with the dog!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superdupervtec »</TD></TR><TR><TD CLASS="quote">I have Gsr/Sir lines on my eg with type r brake swap, I'm pretty sure they are earls, and they are tight, not proper, you need itr, the rotors push out the calipers further and you need the itr ones, They will fit but it's stretching it. I plan on selling mine over the winter to get the proper ones in. Rear are the same.</TD></TR></TABLE>
All part #s are the same for these apps so I believe that there is not specific brake line for the ITR. Im using the Integra/civic lines on my car my lines are not being stretched.
Circuit,
Aftermarket brakes lines are the same for ITR & non-itr?
OEM has different part numbers for the rears for several different years:
Application OEM Price
1997 ITR Right Rear 01466-ST7-R00 $28.48
Left Rear 01468-ST7-R00 $28.48
2001 ITR Right Rear 01466-S03-Z00 $23.60
Left Rear 01468-S03-Z00 $23.60
1994 LS Right Rear 01466-SR3-903 $23.92
Left Rear 01468-SR3-902 $23.92
1994 GSR Right Rear 01466-SR3-903 $23.92
1997 GSR Right Rear 01466-S04-900 $32.67
Left Rear 01468-S04-900 $32.67
xtrafastcivic
Suspension & Brakes
Mar 10, 2006 09:46 PM
navin
Dec 30, 2003 11:29 PM
