Weird noises when turning *searched**VIDS**cv axles replaced**
Old Aug 8, 2005 | 08:35 PM
97Alex's Avatar
Default Weird noises when turning *searched**VIDS**cv axles replaced**
I searched and didnt come up with nothing except cv axles.
Ok, well i replaced pass side axle b/c boots were torn and it made a lotta clunking noises at low speeds and turns etc..I used a re-man'd axle and as soon as i put everything back together i STILL here noises , except this time im getting different sounds. I figured i was given a bad axle so i installed another one. Same thing!
Now, the the boot that is connected to the outer tie rod end on the rack and pinion is torn and there is some grease seeping out; could this be the culprit?
I can hear the noise after turning the wheel to furthest to left or right AND then backing it out into opposite direction. I included a vid so you could hear for yourselves.
Tie rods, lower ball joints, rack n pinion i all gotta check.
I recall turningthe wheel while the wheels were off the ground but i didnt hear anything.
VID VID VID
http://s19.yousendit.com/d.asp...6GQPU
Somebody let me know when it expires or maxes out.
Old Aug 8, 2005 | 08:39 PM
97Alex's Avatar
95 integra by the way
Old Aug 19, 2005 | 12:16 PM
97Alex's Avatar
I guess theyre just cheap *** axles. Never again will i buy reman'd axles.
Old Aug 20, 2005 | 03:36 AM
purplehazehatch's Avatar
Default Re: Weird noises when turning *searched**VIDS**cv axles replaced** (97Alex)
the noise is mast likey the wheel bearing i had a integra to do that
ZXiPoZ
May 30, 2012 10:15 AM
ak1059
Sep 17, 2010 05:12 PM
tamadrummer1120
Oct 13, 2009 07:48 AM
professorman
Suspension & Brakes
Sep 17, 2008 02:23 PM
phongadong
May 7, 2008 09:12 PM
