getto motor mounts?
am getting ready to put a b18 in my 4dr lx and i wanna know if there any getto way to use the motor mounts i already have so that i dont have to buy new ones.also i heard that you only have to use 3 mounts, which ones are they. i have experience at welding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18wagon »</TD></TR><TR><TD CLASS="quote">chezzzz how much gold is in them, thats too much money for me am too cheap</TD></TR></TABLE>
I guess you aren't going to be putting a B18A into your Civic then.
You said you can weld, so fabricate your own mounts if you refuse to buy them.
sounds like you just might have to spend some cash to mount your motor right .
this link won't get you the mounts, but it's a great idea if you have shitty ones. hope this link works for you.
http://forums.clubsi.com/showf...age=0
definitely some mad scientist **** there.
just in case this might help, i got motor mount from both engines, the b18 and the stock one, anyone let me know if there anything i can do does doesnt involve me buying new ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1278886 not bad, i would use them</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TougeCRX »</TD></TR><TR><TD CLASS="quote">i use these ones and i like them https://honda-tech.com/zerothread?id=1278886</TD></TR></TABLE>
those look like the mounts from http://www.streetimports.com
i use streetimports.com mounts in my crx. they are pretty stiff, but i like them.
you can make your stock mounts work...may have to do some drilling and stuff but a friend of mine drilled holes in his mounts from a 88 si and held a b18a1 they work pretty good but there is some flex
.....i would try it and if it dont work then make your own if that dont work go to hasport
FuNkDrSpOt
13
Sep 4, 2005 05:39 AM
