b16 wiring in a 77 austin mini
Old Aug 8, 2005 | 07:59 PM
miniorf's Avatar
Default b16 wiring in a 77 austin mini
so im in the prosses of putting a 2nd gen b16a in my 77 austin mini but it wont run..... i have put a 96 obd2a civic harness on it and and obd 1 conversion adapter. Im using a non chipped p30 ecu. I am not using any of the civic dash harness just powering up what i need off the engine harness plugs. The engine turns over with the starter, it has spark at the plugs and the injectors seem to fire, but it wont run. Any sugestions of places to look, certain sensors, special relays.....?I realize this is a very vage question but any input would be help full. thanks
Old Sep 2, 2005 | 09:27 PM
burgerbuddy's Avatar
Default Re: b16 wiring in a 77 austin mini (miniorf)
you need to give me a lil more info......throwin any check engine lights....timing maybe? ecu? could be a hell of alot of things.....does it crank really fast....if it does might wanna do ur cam timing over and make sure everythings at tdc
Old Sep 3, 2005 | 05:54 AM
turborookie's Avatar
that's a bad *** project you got going any pic's?
Old Sep 3, 2005 | 07:44 AM
john breezy's Avatar
Default Re: b16 wiring in a 77 austin mini (turborookie)
check all your ground....valve cover, tranny ect.
Old Sep 5, 2005 | 08:25 AM
Default Re: b16 wiring in a 77 austin mini (john breezy)
may seem very stupid but...ya got gas in it right?
its been a while since you posted so...did u ever get it runnin
Old Sep 5, 2005 | 08:28 AM
mmuller's Avatar
Mad Scientist
what did you do about the main relay?
Old Sep 21, 2005 | 09:48 AM
hxtasy's Avatar
wow def. post some pics AWSOME project.
where did you buy your dizzy from?
sometimes you get the wrong things on ebay and such.
Old Sep 21, 2005 | 06:58 PM
locash's Avatar
Did you use a stock civic harness? If so, you need to add some relays and do quite a bit of rewiring to make that work..
66fasty
Dec 21, 2007 08:49 PM
miniorf
Aug 9, 2005 11:06 AM
Du_Ma
Mar 16, 2004 09:11 AM
LSVtecEK1
Apr 25, 2003 09:18 PM
sydag5
Oct 7, 2002 08:36 PM
