91 honda accord motor in a 94 accord
Old Aug 8, 2005 | 07:25 PM
epac20's Avatar
Default 91 honda accord motor in a 94 accord
i want to know what things r needed to put a 91 accord motor in a 94 accord shell
Old Aug 8, 2005 | 08:34 PM
uncle_el's Avatar
Default Re: 91 honda accord motor in a 94 accord (epac20)
not sure why you'd want to take a step back, as a 1991 honda accord motor will likely have less horsepower.
are you sure you don't mean a 1994 engine into a 1991 accord shell? that would make a little more sense, as you'd be getting a slight horsepower gain.
Old Aug 8, 2005 | 08:54 PM
P_Adams's Avatar
Call me crazy; but aren't both engines F22's??? Should be a direct bolt in unless one is a vtec. (or I'm nuts)
P
Old Aug 8, 2005 | 08:56 PM
i20ar's Avatar
Default Re: 91 honda accord motor in a 94 accord (P_Adams)
theres kinda a difference from an f22a1 and an f22b1
Old Aug 8, 2005 | 09:13 PM
P_Adams's Avatar
Default Re: 91 honda accord motor in a 94 accord (Dj14aZnS)
Uh Huh, like Vtec and non Vtec. The difference is in the head.............
Old Aug 9, 2005 | 05:38 AM
typhoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncle_el &raquo;</TD></TR><TR><TD CLASS="quote">not sure why you'd want to take a step back, as a 1991 honda accord motor will likely have less horsepower.
are you sure you don't mean a 1994 engine into a 1991 accord shell? that would make a little more sense, as you'd be getting a slight horsepower gain.</TD></TR></TABLE>
Maybe he has a f22a sitting around, and he has a 5th gen shell sitting around.
Old Aug 9, 2005 | 07:33 AM
i20ar's Avatar
yea technically your right i guess..
Old Aug 9, 2005 | 08:41 AM
tournapart's Avatar
f22a's are better in my opinion, but it all comes down to what you going to do with it
Old Aug 9, 2005 | 03:25 PM
JohnnyTequila's Avatar
Default Re: 91 honda accord motor in a 94 accord (tournapart)
isnt this illegal?
by emissions standards, if you swap a motor into the car that is older than the model year of the vehicle, thats illegal. Motor has to be newer than the vehicle its going into.
im pretty sure they are strict on this in cali, dont know about the rest of the US.
if youre buying the motor i suggest getting a newer one, but if you have it laying around, or in a donor car... the swap should be relatively simple. the only thing you should have to worry about is the OBD wiring. IIRC 90-92 accord are OBD0, and 93 is the first year accords are OBD1, until 96 when they went OBD2.
Old Aug 9, 2005 | 03:45 PM
Diego Dangers.'s Avatar
i am guessing the vacuum lines would be the bitch, its kinda wierd on the 91s, but if its already all assembled, should be cake.
Old Aug 9, 2005 | 04:45 PM
P_Adams's Avatar
Default Re: 91 honda accord motor in a 94 accord (JohnnyTequila)
IF you swap in the '91 long block assembly (block & head) but use the manifolds, dist and emissions items from the '94, no one will know the difference. (and it will pass muster every time.
P
Donald Ethel
Jun 29, 2015 04:40 AM
MistaKilla
Jul 28, 2011 06:37 AM
nikt515
Jun 6, 2008 06:23 AM
