HOW DO I INSTALL A TACK?
Old Feb 21, 2002 | 10:38 AM
-=TWITCH=-'s Avatar
Default HOW DO I INSTALL A TACH?
if you know the easist way to install a tach please let me know i have a 91 civic dx hatch thanks alot i know you have to tap the shift light into a power source would the clock plug work i dont have a clock in my car put the plug for it is there do you know witch color wire i have to cut and splice thanks! thought id ask before i went out and bought a tach!
[Modified by -=TWITCH=-, 8:07 PM 2/21/2002]
Old Feb 21, 2002 | 10:43 AM
Giuseppe's Avatar
Default Re: HOW DO I INSTALL A TACK? (-=TWITCH=-)
power
ground
& B15 at your ECU
have a nice day.!
Old Feb 21, 2002 | 10:44 AM
-=TWITCH=-'s Avatar
Default Re: HOW DO I INSTALL A TACK? (Giuseppe)
little more help i got the power ground part! & B15 at your ECU?
Old Feb 21, 2002 | 10:46 AM
TypeR0207's Avatar
That is the ECU pinout wire that you need to splice into. Check the Helms manual for it, or go to:
http://b16a.honda-perf.org/theswap.html
Old Feb 21, 2002 | 10:53 AM
-=TWITCH=-'s Avatar
Default Re: HOW DO I INSTALL A TACK? (TypeR0207)
i herd even on the dx that there is a wire in the plug for your guage cluster for a tack even though its not being used? is this true has anyone herd of it can i splice in there!!!
Old Feb 21, 2002 | 11:06 AM
Giuseppe's Avatar
splice into the ECU, at B15 i have it there no problems..
trust me!
Old Feb 21, 2002 | 11:37 AM
TypeR0207's Avatar
If you get a gauge cluster from an Si of the same dash style ('88-'89, or "90-'91), it is plug and play. I have a '91 Si cluster in my '90 STD hatch.
Old Feb 21, 2002 | 12:59 PM
brad.'s Avatar
TACH....not TACK
Old Feb 21, 2002 | 01:02 PM
HCrip's Avatar
OK, since you don't want to goto B15, wire it up to the negative side of the coil, or, run a wire to the distributor. Goto http://www.autometer.com and they should have instructions there, as well.
Old Feb 21, 2002 | 01:07 PM
-=TWITCH=-'s Avatar
Default Re: HOW DO I INSTALL A TACK? (HCrip)
ok ill go ecu i just dont think i have enough wire to go that far and what is b15 i know its a wire but witch one im a newbie to wiring! and i will go to my coil but where is the wire!!!!
Old Feb 21, 2002 | 01:16 PM
therealciviczc's Avatar
I recommend not getting a monster tach if that's what you're thinking of, not that you asked or care. I just wanted to give you some food for thought before you spend the money.
A). They're overkill
B). They scream Break in to my car
C). They're annoying after about 3 weeks of driving because they're overkill.
D). They give the V8 guys something to laugh at you for even though your car uses a lot more of the tach than most of theirs.
That's just my opinion though. Pretty much everone that I know that isn't driving a rice mobile or a race car has gotten rid of them. They're just a little too flamboiant (sp).
[Modified by therealciviczc, 10:17 PM 2/21/2002]
Old Feb 21, 2002 | 01:34 PM
jdm civic's Avatar
Default Re: HOW DO I INSTALL A TACK? (therealciviczc)
Old Feb 21, 2002 | 01:37 PM
-=TWITCH=-'s Avatar
Default Re: HOW DO I INSTALL A TACK? (jdm civic)
thanks! for the FOOD
im goint to mount it to the left of my guage cluster my car already says break into me because it looks good.
[Modified by -=TWITCH=-, 10:38 PM 2/21/2002]
Old Feb 21, 2002 | 01:45 PM
daniel89civ's Avatar
si gauge cluster the same year of the car is plug and play 88-89 90-91
i didn't know b15 from ecu works for a tach
Old Feb 22, 2002 | 02:07 AM
brad.'s Avatar
Default Re: HOW DO I INSTALL A TACK? (daniel89civ)
im just getting a JDM cluster....good enough for me
crxrider
Sep 5, 2007 06:34 PM
BlitzSix
Sep 15, 2006 07:11 AM
streetcartuner
Sep 8, 2006 07:19 PM
txracer
Dec 29, 2004 03:17 PM
ironchef25
16
Aug 26, 2004 06:55 PM
