what timing belt do i use for lsvtec, block will have gsr oil and water pump???
Old Aug 8, 2005 | 06:03 PM
eg:R's Avatar
Default what timing belt do i use for lsvtec, block will have gsr oil and water pump???
as title
Old Aug 8, 2005 | 11:47 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: what timing belt do i use for lsvtec, block will have gsr oil and water pump??? (eg:R)
gsr timing belt
Old Aug 10, 2005 | 07:36 PM
QUIKRLS's Avatar
Default Re: what timing belt do i use for lsvtec, block will have gsr oil and water pump??? (PURPLETERROR)
does not matter, ls, is the same size as gsr, just did one today!
Old Aug 10, 2005 | 10:42 PM
Default Re: what timing belt do i use for lsvtec, block will have gsr oil and water pump??? (WHTGEN2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHTGEN2 &raquo;</TD></TR><TR><TD CLASS="quote">does not matter, ls, is the same size as gsr, just did one today!</TD></TR></TABLE>
Wrong, 2 different part numbers, if you use the gsr waterpump, you use the gsr belt, ls pump, ls belt, dont spread misinformation.
Old Aug 14, 2005 | 08:26 AM
reactiondc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">gsr timing belt</TD></TR></TABLE>
Old Aug 14, 2005 | 11:47 AM
Daily Interlude's Avatar
Water pumps are diff size...at least the pulleys are so the belts are diff size.
GSR
Old Aug 16, 2005 | 09:29 PM
lsvtecracer's Avatar
Default Re: (Daily Interlude)
Like purpleterror said, use the the timing belt that match to your water pump. gs-r timing belt if you use gs-r water pump and vice versa.
Old Aug 26, 2005 | 09:51 PM
P-DuBB's Avatar
Default Re: (lsvtecracer)
wat about if u wanna put the car back to stock ls...and u have a gsr timing belt and water pump ...will u need to change them back to ls
Old Aug 27, 2005 | 06:43 AM
Rod.'s Avatar
Default Re: (P-Dubb)
yes change back to the ls
GearheadzAuto
Jan 3, 2008 07:58 AM
timm099
Dec 13, 2006 06:09 AM
SPOOLINmatt
May 18, 2005 09:04 AM
B18 CYA
May 11, 2005 03:11 PM
BoOsTiN Dc2
Feb 7, 2004 02:32 AM
