Setting stock timing on my B18B
Just completed a swap, but timing seems to be off. Just wondering how easy is it to set timing back to stock setting? I have this link I found off here:
http://www.c-speedracing.com/h...g.php
Also where could I get a timing gun or could I do this with out it?
very easy, you can get a timing gun at any autoparts store or barrow a friends. You just loosen the 12mm on the distributor, hooks up the timing gun on the - and+ terimals, hooks up the wire for the spark plug wire (#1 cylinder) and look on the timing belt side cover and aim and point the gun on the crank pulley. look at the little fin and I think stock timing is the one between the 3 markings. really simple thing to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team Envy-us »</TD></TR><TR><TD CLASS="quote">If I were to get it done at a shop, do you know how much it would run ?</TD></TR></TABLE>
go buy your own timing gun, they are like $30-40 at most.
dr_latino999
Dec 2, 2004 09:55 PM
