Trying to find Stock Timing map for 99 Si b16a engine
I am failing at trying to find a stock ignition timing map for a my 99Si b16a engine. I want to know what its total advance timing is at 8,000rpm at full load naturally aspirated. AS in from the factory.
any help is appreciated.
i am told it is like 27.8 degrees, but i want more insight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">Uberdata shows 29.75 degrees. </TD></TR></TABLE>
uberdata does not show 29.75 degrees. it shows 26.25* at 0.35 In/Hg and 25.25* at 1.13 psi. these numbers seem to be aboutthe same as the CROME values
run 25-26* timing for full load at 8K rpms nd then do the boost retard from there. dont run 28* timing, be safe and run low
i stick with my answer i told you last night, 27-28. that's still way under the 33 degress you originally had it setup to run.
here, i'm nice today. two maps, one a conservative timing map, the other an aggressive timing map:
mild
wild
mild
wild
