Boost Gauge install....
Old Aug 8, 2005 | 04:13 PM
radio1global's Avatar
Default Boost Gauge install....
Like the title says, Im wondering where do you guys run the Boost Line threw the fire wall? Any ideas would help out
Old Aug 8, 2005 | 05:38 PM
B20TDC2's Avatar
Default Re: Boost Gauge install.... (radio1global)
run it through the rubber gromet under the brake booster
Old Aug 8, 2005 | 05:58 PM
debogsr's Avatar
Default Re: Boost Gauge install.... (B20TDC2)
Use the hole under and to the right of the battery. Theres a rubber plug you can pop out easily.
Old Aug 8, 2005 | 07:02 PM
Do you mean the gromet for the elec. harness?
And also I think that the battery location would be too far of line for the gauge to read
accurate?
Old Aug 10, 2005 | 04:51 PM
torqueless's Avatar
Default Re: (radio1global)
is there a site such as autometer, with full instructions? i know where to T in the vaccum line, but am clueless where the wires splice into.
Old Aug 10, 2005 | 10:45 PM
acuradriva's Avatar
Default Re: (torqueless)
You just need power (12V) and ground to run the light in the gauge. So if you hook it up to the gauges lighting wiring it will come on when you turn on the headlights. Tell us what year car and we may be able to telll you what color wire you need to tap into.
Old Aug 11, 2005 | 02:21 AM
no2unenolife's Avatar
theres a rubber grommet under the brake booster, poke a hole and push the line through.
Old Aug 11, 2005 | 02:32 AM
98BlackTeg's Avatar
Default Re: (no2unenolife)
Yep, under the brake booster. It's a solid grommet. Punch a hole in it or buy one from Autozone that already has a hole. Then if you need to seal it, use a little black RTV.
Old Aug 11, 2005 | 06:09 AM
7k rdlne's Avatar
Default Re: (98BlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">Yep, under the brake booster. It's a solid grommet. Punch a hole in it or buy one from Autozone that already has a hole. Then if you need to seal it, use a little black RTV.</TD></TR></TABLE>
i concur, i used that location for mine
K i l l a B e e.
Oct 29, 2007 08:56 AM
radio1global
Jun 3, 2005 12:59 PM
boostdB16a
Jul 28, 2003 11:48 AM
CBR600OnTop
Mar 15, 2003 01:06 PM
5thgencivic
Mar 12, 2003 04:34 PM
