most whp on CTR / ITR cams ?
Old Aug 8, 2005 | 11:39 AM
MOTOCOMPO's Avatar
Default most whp on CTR / ITR cams ?
whats the highest whp you've seen with R cams? just wondering what these things are capable of.
Old Aug 8, 2005 | 12:43 PM
xEnderx's Avatar
Default Re: most whp on CTR / ITR cams ? (MOTOCOMPO)
I'm wanting to say that I've seen in the 200 hp range.
Old Aug 9, 2005 | 10:17 AM
k20b's Avatar
Default Re: most whp on CTR / ITR cams ? (xEnderx)
how can someone tell the differance between stock b16 cams ,itr's and ctr cams?
Old Aug 9, 2005 | 03:01 PM
Jowee's Avatar
Default Re: most whp on CTR / ITR cams ? (k20b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20b &raquo;</TD></TR><TR><TD CLASS="quote">how can someone tell the differance between stock b16 cams ,itr's and ctr cams?</TD></TR></TABLE>
Go searching and you'll be able to find it.
I've seen OEM ITR/CTR cams hit a little higher than 200whp with enough compression.
Old Aug 10, 2005 | 12:30 PM
MOTOCOMPO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">I'm wanting to say that I've seen in the 200 hp range.</TD></TR></TABLE>
definitely over 200whp. think 230whp is possible with the right block?
Old Aug 10, 2005 | 12:40 PM
CRVTEC0WNZJ00's Avatar
I'd say 215whp is possible with a really good tune, good boltons, and some head work.
Old Aug 25, 2005 | 10:22 PM
FROSTDC2's Avatar
Default Re: most whp on CTR / ITR cams ? (CRVTEC0WNZJ00)
i got fully built gsr, bottom block- 11.5:1 wiseco pistons, shot peened R rods, .50 overbore, decked .20, toda 2mm headgasket, head is gsr port and polished, 3 angle valve job, toda dual valve springs, jun titanium retainers, type r valves, i had crower stage 2s in it but i think they blew my last motor so i dont want a repeat, what do u think i would get with ctr cams with this set up, i also have a kenji p28 ecu, skunk2 pro series mani, erik racing tb, dc type r headers, apexi gt spec exhaust, aem cold air, aem fuel pressure regulator, 310 rc injectors... thanx alot
Old Aug 26, 2005 | 07:36 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVTEC0WNZJ00 &raquo;</TD></TR><TR><TD CLASS="quote">I'd say 215whp is possible with a really good tune, good boltons, and some head work.</TD></TR></TABLE>
I should be in the 215 with my build and CTR cams...I would think that's about all you can make...possibly 230 with tuning...we shall see
Old Aug 26, 2005 | 08:53 AM
carboy_honda's Avatar
I did 246hp at the flywheel forgot the whp thoug but should be close around 180-190.This was done on a JDM ITR with PNP ,stock 4-1 header with racing exhaust,Mugen headgasket,stock ITR intake .This was my N1 engine
Old Aug 26, 2005 | 02:28 PM
Bradstard's Avatar
92TypeR was still running his ITR cams when he first got his fully built 2.0L running. I want to say he was pushing in the 210whp range??? I may be wrong, I'll get him to chime in.
Old Aug 26, 2005 | 04:06 PM
91civicDXdude's Avatar
why does everybody ride the type r cam band wagon? usually i see these cams going for more money than aftermarkets which will make more power 99% of the time.. it just seems a waste.
i could compare it to a v8 guy building a block with 12:1 compression, big *** carb, intake manifold, bad *** headers, and then using an "rv cam"
if you're going to build an engine, get some real cams. sure, power has been made with these oem cams, but i guarantee that in identical setups, some stage 2 aftermarkets will make more power.
Old Aug 26, 2005 | 04:26 PM
Rocket's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">power has been made with these oem cams, but i guarantee that in identical setups, some stage 2 aftermarkets will make more power.</TD></TR></TABLE>
True true.
If you wan to get power from smaller cams you can port the head accordingly but getting bigger cams is a easier and more feasible route.
Old Aug 26, 2005 | 10:31 PM
b18c5swap's Avatar
Running B18c5 all stock with few bolt ons and vafc 207whp
Old Aug 26, 2005 | 10:33 PM
FROSTDC2's Avatar
Default Re: (Rocket)
ya i had crower stage 2 but it made too much power, i dont have crower srpings and retainers, and toda and jun... the cams r too big and require crower vtrain, so im thinkin about skunk2 stage 1... what do u think?
Old Aug 27, 2005 | 09:07 AM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">why does everybody ride the type r cam band wagon? usually i see these cams going for more money than aftermarkets which will make more power 99% of the time.. it just seems a waste.</TD></TR></TABLE>
700whp... http://forums.evans-tuning.com...=2360
630whp... http://forums.evans-tuning.com...=1995
615whp... http://forums.evans-tuning.com...=2481
601whp... http://forums.evans-tuning.com...=2550
595whp... http://forums.evans-tuning.com...=2475
I know these cars are turbo, but I think cars like this might have something to do with it. All these cars are using CTR/ITR cams. I only listed a few and there were plenty making this much power with GSR cams as well.
For all motor I do see what your saying though. I guess some guys just like sticking with OEM parts.
Old Aug 27, 2005 | 09:12 AM
vart's Avatar
I think some people find more reliability in using oem parts.
Old Aug 27, 2005 | 09:20 AM
JDMisGOOD's Avatar
Default Re: (vart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vart &raquo;</TD></TR><TR><TD CLASS="quote">
I think some people find more reliability in using oem parts.</TD></TR></TABLE>
Time proven technology and reliablilty! 220+ is very possible
Old Aug 27, 2005 | 01:39 PM
Default Re: (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">Time proven technology and reliablilty! 220+ is very possible </TD></TR></TABLE>
im not saying those power levels arent very possible, all im saying is that they are even easier to get using bigger cams. I understand that honda reliability is a proven thing, but purposely limiting one area of engine development/power output for "honda reliability" doesnt make that much sense to me.
Also realize that the type r cams were designed with a certain power level in mind, and most likely perform the best inside of that window.
and as far as those turbo graphs that bbka posted, i can almost guarantee with 100% accuracy that if they had bigger cams and/or properly designed cams to go with the engine setup, they would make more power. I guess its a tribute to OEM Honda engineering?
Old Aug 27, 2005 | 04:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">and as far as those turbo graphs that bbka posted, i can almost guarantee with 100% accuracy that if they had bigger cams and/or properly designed cams to go with the engine setup, they would make more power. I guess its a tribute to OEM Honda engineering?</TD></TR></TABLE>
I'm sure they would, but do you really need more than 600 or 700whp? Power isn't everything. I would trade horsepower for traction anyday. All those cars have plenty of power to run sub 10 second 1/4 mile times... that's pretty damn fast.
I think the point I was trying to make is that's why people like the ITR/CTR cams so much, plus if you already have them you won't need to spend more money on aftermarket cams. For all motor it's a different story though since you don't have a turbo to make all your power for you.
Also I have seen a few builds and know a few people that just like to keep everything OEM... I guess it's more of a challenge.
Old Aug 28, 2005 | 10:56 AM
vart's Avatar
it also depends on what kind of build you are doing. If you are going to do a crazy build, then having mild cams would not be a smart choice. but if it is just a mild street build, then these cams would be a smart, reliable choice...
Old Aug 28, 2005 | 01:11 PM
92TypeR's Avatar
FSAE
Default Re: (vart)
184/132 on the mustang dyno from this year's ITR expo.
That particular dyno averages 14-16% lower than the standard DynoJet 248 series.
At 14% the equivilent dynojet power is
210whp/150wtq
Specs are at my site: http://www.itrspec.com
Old Aug 28, 2005 | 05:03 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: (92TypeR)
Tuned for longevity, for a track car. Could go higher, but at a cost.
Old Aug 29, 2005 | 10:15 AM
Rocket's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Tuned for longevity, for a track car. Could go higher, but at a cost. </TD></TR></TABLE>
Agree. There's different types of tunes. Like qualifying and last race of the weekend, the year etc.
integraboosted
Aug 18, 2006 04:40 PM
crxh22project
30
Jul 24, 2005 02:24 PM
kenepo_vtec
Jul 4, 2004 08:57 PM
MUGEN_B16CIVIC
12
Mar 27, 2004 07:49 AM
Unjockable
16
Jul 11, 2002 11:58 PM
