New motor wont turn over at all with new ignition system help
Old Aug 8, 2005 | 09:08 AM
001020's Avatar
Default New motor wont turn over at all with new ignition system help
Okay I just finished building my motor but it wont start. The 1st obvious reason it will not start is that I do not have an ECU for it as yet but it is still supposed to be able to crank, which it is not doing. I have a MSD 6A hooked up and for now, just to get it started, I just used the stock 7.5mm wires. and the external blaster coil I got from this kid..and A new rotor in my dizzy... anyway I hooked up everything the right way and I do not get any spark.. I keep hearing click, click, click, and no spark and the motor is not trying to turn over. I know I’m not getting spark because I pulled the plug out and attached a spark plug to it and nothing…. I have a brand new battery. the timing is correct…the dizzy is fine. the dizzy cap is new…the 7.5mm wires are new(yes I am changing them). My assumptions are #1 the starter is bad, #2 the coil I got from that kid is bad….am I missing out on anything, or I hope its not #3 the MSD is bad because I purchased a brand new one…SO any other things that can cause this? summary:no comp, getting fuel, no spark, click click click, new msd ignition system cap rotor, used coil...help
Old Aug 8, 2005 | 12:03 PM
cibola's Avatar
Default Re: New motor wont turn over at all with new ignition system help (001020)
Make sure all of your ground straps are connected. Its most likely a real easy electrical fix.
Old Aug 8, 2005 | 12:22 PM
CrotchRocket's Avatar
Try testing your coil by connecting the + and - from the ICM in the distributor then try starting the engine. See if that works, I had the same problem by the way but my MSD SCI was the culprit.
Old Aug 8, 2005 | 01:00 PM
EE_Chris's Avatar
You have no ECU hooked up, yet expect spark??
Old Aug 10, 2005 | 05:13 AM
001020's Avatar
Default Re: New motor wont turn over at all with new ignition system help (EE_Chris)
Okay but the motor is supposed to turn over but not start without a ecu....and once your engine turns that = u getting spark I know because we used to take out our ecu as a extra security measure and my friend forgot it was out and tried to stat the car
Old Aug 10, 2005 | 07:46 AM
EE_Chris's Avatar
You're suggesting that even without the ECU, so long as the motor is able to turn over via the starter, a spark will be generated??
No.
Old Aug 10, 2005 | 08:05 AM
FIST321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 001020 &raquo;</TD></TR><TR><TD CLASS="quote">Okay I just finished building my motor but it wont start. The 1st obvious reason it will not start is that I do not have an ECU for it as yet but it is still supposed to be able to crank, which it is not doing. I have a MSD 6A hooked up and for now, just to get it started, I just used the stock 7.5mm wires. and the external blaster coil I got from this kid..and A new rotor in my dizzy... anyway I hooked up everything the right way and I do not get any spark.. I keep hearing click, click, click, and no spark and the motor is not trying to turn over. I know I’m not getting spark because I pulled the plug out and attached a spark plug to it and nothing…. I have a brand new battery. the timing is correct…the dizzy is fine. the dizzy cap is new…the 7.5mm wires are new(yes I am changing them). My assumptions are #1 the starter is bad, #2 the coil I got from that kid is bad….am I missing out on anything, or I hope its not #3 the MSD is bad because I purchased a brand new one…SO any other things that can cause this? summary:no comp,getting fuel, no spark, click click click, new msd ignition system cap rotor, used coil...help</TD></TR></TABLE>if u dont have an ecu how is it get fuel i mean maybe i am reading it wrong anyways i would check tour to see if its geting 12v to the starter
nhamilton122
21
Apr 22, 2012 03:31 PM
NeKe1point0
Jan 21, 2008 06:07 PM
Blown99civicsi
Jun 4, 2005 09:01 AM
CivicSiRracer69
Nov 27, 2004 12:30 PM
AccordDX89
May 18, 2004 10:47 AM
