93 se rotor change
Old Aug 8, 2005 | 08:44 AM
icet's Avatar
Default 93 se rotor change
hi guys,
wonder if 93 se accord coupe front rotor hold by 2 screws or pressed in?
would to change them for my niece, thanks...
icet
Old Aug 8, 2005 | 08:57 AM
THEROPE's Avatar
Default Re: 93 se rotor change (icet)
its a floating rotor meaning its held by the studs and the two screws
Old Aug 8, 2005 | 09:00 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 93 se rotor change (THEROPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEROPE &raquo;</TD></TR><TR><TD CLASS="quote">its a floating rotor meaning its held by the studs and the two screws</TD></TR></TABLE>
I thought the 90-93 front rotors were the same as the 94-97 front rotors which are hub-over-rotor?
Edit: oops, glad no one caught that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icet &raquo;</TD></TR><TR><TD CLASS="quote">hi guys,
icet</TD></TR></TABLE>
Not trying to sound rude but try running a search. This has been covered before and you'll find more info in a shorter amount of time than waiting for people to reply.
Modified by TouringAccord at 2:31 PM 8/8/2005
Old Aug 8, 2005 | 09:24 AM
deserthonda's Avatar
Default Re: 93 se rotor change (TouringAccord)
[QUOTE=TouringAccord]
I thought the 90-93 front rotors were the same as the 94-97 front rotors which are rotor-over-hub
mm they are that is the second guy that talks about the 2 screws on a rotor over hub system ... there are 4 14mm bolts no 2 screws if it is frt rotors 90-97 axccords
Old Aug 8, 2005 | 10:05 AM
twistedbydezign's Avatar
Default Re: 93 se rotor change (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=TouringAccord]
mm they are that is the second guy that talks about the 2 screws on a rotor over hub system ... there are 4 14mm bolts no 2 screws if it is frt rotors 90-97 axccords</TD></TR></TABLE>
they are pressed, the rear discs if you have them are 2 screws/rotor over hub, you can do a front hub swap with an acura cl i believe it is that will convert it to rotor over hub but is a lot of work if change your rotors on a normal schedule and not twice a year...
Old Aug 8, 2005 | 10:43 AM
H-T Order of Merit
Default Re: 93 se rotor change (buffalo wings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buffalo wings &raquo;</TD></TR><TR><TD CLASS="quote">they are pressed, the rear discs if you have them are 2 screws/rotor over hub, you can do a front hub swap with an acura cl i believe it is that will convert it to rotor over hub but is a lot of work if change your rotors on a normal schedule and not twice a year...</TD></TR></TABLE>
Correct, the rear rotors are rotor-over-hub. And yes, there are a couple write-ups on converting the front rotors from hub-over-rotor to rotor-over-hub using Accord bearings, CL hubs and rotors. There are two different caliper set-ups you can use as well with conversion. One is to use the stock calipers with 2.3 CL hubs and 2.3 CL rotors and the other is to use Legend dual piston caliper/ 95-02 AV6 caliper/ 93+ Prelude VTEC caliper/ 98+ ITR caliper with 2.3 CL hubs and 3.0 CL rotors.
I think even the simple rotor-over-hub conversion is worth it. I was planning on doing this the next brake change but the Accord was totalled before that time came around.
Old Aug 8, 2005 | 01:01 PM
icet's Avatar
thanks for all the reply....
i did search and not enough info...
after read all the replies, i am confused...
is it press or 2 screw?
i don't plan to conversion....
thanks...
Old Aug 8, 2005 | 05:55 PM
H-T Order of Merit
Default Re: (icet)
ok, your still confused?
Your stock set-up is hub-over-rotor in the front. You don't need a press all the time. If all goes as planned, a press is not needed.
If you want to replace the rotors, heres a quick step by step.
With the car on the ground, loosen the axle nut.
Lift and support the car.
Remove the tire.
Remove the axle nut.
Have someone hold the brakes and loosen the four bolts holding the rotor to the hub.
Remove the caliper and zip tie it out of the way.
Remove the caliper bracket.
Remove the cotter pin from the lower ball joint castle nut.
Remove the castle nut.
Hit the lower control arm where the ball joint goes into it. This will pop it free.
Remove the axle from the hub.
Remove the four bolts holding the bearing onto the hub.
If the hub/rotor/bearing assembly doesn't drop away from the knuckle try hitting the rotor with a hammer to try freeing it.
If this doesn't work, I would recommend removing the knuckle from the car and take it to a machine shop and have them press everything apart and put everything back together.
If it drops away, remove the four bolts that hold the rotor to the hub that you loosened earlier.
Then slip the rotor over the bearing.
Then just reassemble everything in reverse order.
Hope this helped.
If I missed something please correct me.
Old Aug 9, 2005 | 06:03 AM
icet's Avatar
thanks for your help touring accord...
icet
Old Aug 9, 2005 | 07:45 AM
THEROPE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by TouringAccord at 2:31 PM 8/8/2005</TD></TR></TABLE>
i thought honda started the hub over rotor on the 94 models i didnt know that they also did it for 90-93
Old Aug 9, 2005 | 06:23 PM
H-T Order of Merit
Default Re: (icet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icet &raquo;</TD></TR><TR><TD CLASS="quote">thanks for your help touring accord...
yep, np.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEROPE &raquo;</TD></TR><TR><TD CLASS="quote">i thought honda started the hub over rotor on the 94 models i didnt know that they also did it for 90-93 </TD></TR></TABLE>
yep, 90-97 Accords have basically the same front brake set-up.
Old Aug 9, 2005 | 07:47 PM
H0ndaJunkie's Avatar
Default Re: (TouringAccord)
that's bizarro, because my 97 accord SE has the rotors over the hubs, held on by two pain in the *** screws.
Old Aug 10, 2005 | 06:13 AM
H-T Order of Merit
Default Re: (H0ndaJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0ndaJunkie &raquo;</TD></TR><TR><TD CLASS="quote">that's bizarro, because my 97 accord SE has the rotors over the hubs, held on by two pain in the *** screws.</TD></TR></TABLE>
Are you refering to the front or the rear?
If you are refering to the front then the original/previous owner probably converted to 2.3 CL hubs and rotors, lucky you.
Old Aug 10, 2005 | 06:36 AM
Rad Racing's Avatar
Bart Taylor Look-alike
I nominate TouringAccord for "Teacher of the Year" award. He went beyond the call of duty to help a H-Ter out
Old Aug 10, 2005 | 10:51 AM
H-T Order of Merit
Default Re: (Rad Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rad Racing &raquo;</TD></TR><TR><TD CLASS="quote">I nominate TouringAccord for "Teacher of the Year" award. He went beyond the call of duty to help a H-Ter out </TD></TR></TABLE>
lol, thanks
Just trying to help out.
LandHard
Aug 12, 2009 07:25 AM
Joetravelall
Feb 20, 2007 03:25 AM
MI4$DC5
Nov 13, 2006 06:37 PM
whitelightning
May 6, 2004 06:29 AM
blackintegra
Jul 29, 2003 09:18 PM
