NEED HELP!!!!!
Old Aug 8, 2005 | 08:23 AM
C_REX's Avatar
Default NEED HELP!!!!!
Anyone know why my D16A6 wont go past 4,000 rpm...? It's got a stock ECU PM6 and I also try the PM8 ECU too but that will only let me go up to 3500 Rpm and nothing higher. You think it could be the some wiring problems...? I've checked everything and it seems to be koo.. and no engine check light either. Any ideas guys...? Thanks!
Old Aug 8, 2005 | 08:40 AM
C_REX's Avatar
Default Re: NEED HELP!!!!! (C_REX)
bumper!!
Old Aug 8, 2005 | 10:37 AM
C_REX's Avatar
lunch bump!
Old Aug 8, 2005 | 10:38 AM
ef8 h0!'s Avatar
you sure no CEL's?
Old Aug 8, 2005 | 10:53 AM
C_REX's Avatar
Default Re: NEED HELP!!!!! (ef8 h0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8 h0! &raquo;</TD></TR><TR><TD CLASS="quote">you sure no CEL's?</TD></TR></TABLE>
Yep. 110% for sure.. The ecu is not even blinking at all and it sucks to have a 4000rpm rev. limiter!
Old Aug 8, 2005 | 10:57 AM
crx-treme's Avatar
well is this a swapped d16a6? or was it already in the car adn this is a new problem? tell us more
Old Aug 10, 2005 | 07:33 AM
C_REX's Avatar
Default Re: NEED HELP!!!!! (crx-treme)
It's a swap... just to get it running for now to get tabs and smog test, then another swap later, but i still want this D16 to run right tho. Having to shift at 4k rpm is fucken weak! I even changed the distributor too and same ****.
Also, when i got car the guy had it before me was using MSD and some other ****, so that might be the problem...?
Old Aug 10, 2005 | 09:23 AM
C_REX's Avatar
bumpppppppp
Old Aug 10, 2005 | 03:03 PM
C_REX's Avatar
Bang it up!
turboteg90
Jun 24, 2008 11:52 PM
Mike Diaz
Dec 14, 2006 12:48 PM
bgoetz
May 23, 2006 01:02 AM
jlucas
Jul 6, 2003 05:42 PM
riceball777
Jun 4, 2003 09:46 AM
