Blown compression rings on a B16A. Going to tear the head off to check.
Old Aug 8, 2005 | 07:44 AM
blaze the chemi's Avatar
Default Blown compression rings on a B16A. Going to tear the head off to check.
Hey fellas!
I have a B16A (first generation) in my 00 Si with possible compression rings blown or cracked. The compression test came back reading #1 cylinder 70 psi and the other 3 @ 170 psi. The leak down test gave a 65% loss of air which really sucks. I am planning on doing this myself with some help of friends.
I need a little advice from you all that have done this. I have the Helms and I am going through all the steps and will be getting the appropriate tools from the dealership, or a good Auto store. Upon inspection after taking the head off we will be able to see if the piston is cracked as well. I am sure the ringlands have started to go since this car is boosted. Let me know of some good pointers so this replacement can go smoothly as possible. I do plan on getting the head checked out while it is off. Thanks!
Old Aug 8, 2005 | 08:28 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Blown compression rings on a B16A. Going to tear the head off to check. (blaze the chemi)
unless it is catastrophic, you wint see a ringland cracked. once you get the piston/rod assembly out you will see the rings and the lands if they are dammaged.
MrMug3n
Jul 11, 2008 07:13 PM
widecrx
Jul 21, 2007 02:58 PM
Unlimitationz
Feb 22, 2005 03:47 PM
98civicEX
Apr 8, 2003 10:55 AM
