ECU location?
Old Aug 8, 2005 | 06:33 AM
CockerCid's Avatar
Default ECU location?
I'm having a little jproblem finding the ECU in fiances's Accord. It's a '99 Accord V6. I haven't had much experience with accords. most of my work has been with older civics. The car is throwing some kind of code and I got a scanner to find out what's going on, but when I checked out the passenger side... all I could find was a blower motor and a fuse panel. Is it on the driver side? under the hood? someone please help me out here. The "maintenance required" and "check engine" lights are on. the engine at idle sounds ok, but the exhaust seems to gurgle a bit (which it wasn't doing before) and the engine seems to want to die out at around 3500 RPM.... I have a few ideas on what it is, but if anyone has any suggestions on what this could be, I would greatly appreciate it.
Thanks.
Old Aug 8, 2005 | 06:45 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: ECU location? (CockerCid)
Did you only look in the side panel of the passenger side foot area?
I don't know if they are the same but on my 95 EX it was located under the passenger side kick panel. Pull the carpet back, if it's the same as the 5th gens, then you should see a kick panel where the floor and the firewall meet. Under it would be the ECU. Like I said, it may not be the same but it doesn't hurt to look.
Old Aug 8, 2005 | 06:55 AM
CockerCid's Avatar
Default Re: ECU location? (TouringAccord)
yeah, I pulled the carpet back as far as I could without taking off the center console and it wasn't there , but thanks
Old Aug 8, 2005 | 06:56 AM
tom10e's Avatar
The ecu is under pax carpet. But the scanner plug is behind the ashtray(center lower console).
Old Aug 8, 2005 | 07:09 AM
-Bionic-'s Avatar
Former Sponsor
For the 6th gen. The ECU is located by the floor between the driver and the passanger side. Pretty much right below the center console.
Old Aug 8, 2005 | 07:24 AM
CockerCid's Avatar
Default Re: ECU location? (-Bionic-)
Awesome, that makes sense . Thanks a lot.
Old Aug 8, 2005 | 08:03 AM
i20ar's Avatar
since this was resolved.. i was just wondering.. how do you remove the carpet to the ECU without messing it up ... and when you put the carpet back down is it loose now?
Old Aug 8, 2005 | 08:57 AM
H-T Order of Merit
Default Re: ECU location? (Dj14aZnS)
umm, I don't remember exactly since I only removed the carpet once and that was when I was stripping the car after it was totalled. But I want to say there was one or maybe two clips that held it into place at that spot. Just pull the clip(s) free to remove the carpet and then just reinsert them to hold the carpet back down. It should hold just the same as it did before. If the clip stripped when you removed it, just go to Honda and get another one. Should be around $2 ea. or so. I had bought a couple when I replaced the carpet in my hatch and I think thats what they cost.
Old Aug 8, 2005 | 09:58 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote"> there was one or maybe two clips that held it into place at that spot. Just pull the clip(s) free to remove the carpet and then just reinsert them to hold the carpet back down. It should hold just the same as it did before. </TD></TR></TABLE>
Old Aug 8, 2005 | 05:53 PM
hondadude's Avatar
if you have a scan tool, why do you want to find the ECU? I'd hook up the scan tool to the OBD2 connection at the top of the drivers side kick panel. Read the code and diagnose from that point.
Old Aug 10, 2005 | 08:09 AM
CockerCid's Avatar
Default Re: ECU location? (hondadude)
I guess I should've worded it differently. But, I hooked up the scanner, turns out it's "air/fuel metering" so I'll start by checking the obvious things first. But that still leaves the question of why the engine doesn't want to go above 3500 rpm. unless it's a safety device preventing VTEC from kicking in.
Anywho, thanks for the help.
bookzguy
Dec 18, 2013 03:42 PM
George2012
Classic Hondas
Oct 31, 2012 11:48 AM
Hutchinfun
Apr 3, 2010 12:16 PM
mattf22b1
Apr 26, 2006 06:12 AM
vtec.dc2
Oct 7, 2003 07:42 PM
