4 wire 02 sensor, pulled out, need help! searched
Old Aug 8, 2005 | 01:00 AM
tur3oDC4's Avatar
Default 4 wire 02 sensor, pulled out, need help! searched
Alright, I removed my header a while back, and along with it came my o2 sensor. The wires pulled right out of the plug, I can push them back in, but i dont know what order they go. Can someone please help - thanks
Old Aug 8, 2005 | 01:11 AM
jthm's Avatar
Default Re: 4 wire 02 sensor, pulled out, need help! searched (CrookedDC4)
The wires should be color coded. Check the wires from the harness and match them together.
Old Aug 8, 2005 | 02:21 AM
tur3oDC4's Avatar
Default Re: 4 wire 02 sensor, pulled out, need help! searched (squee)
they dont match
Old Aug 8, 2005 | 04:11 AM
internetautomart's Avatar
if the wires pulled out of the sensor itself, then replace it.
if they pulled out of the harness on the car, then I'd suggest finding someone with the same exact car and match up the color codes that way.
someone here may be nice enough to take a pic for you.
Old Aug 8, 2005 | 06:14 AM
Duane_in_Japan's Avatar
Try this
O2S Engine Harness
BLACK GRN / RED
BLACK BLK / YEL
WHITE BLU / RED
GREEN ORG / BLU
BLACK BLK / WHT
BLACK YEL / BLK
WHITE WHT
GREEN GRN / BLK
THIS IS A 1.8L 1996 MODEL, you didnt give any info at all, and I mean none. You should put your cars info in your signature block.
This car has two sensors, let me know if this does it, the heater black wires on the sensor are DC so I do not think that it matters which way they go.
Old Aug 8, 2005 | 06:16 AM
Default Re: 4 wire 02 sensor, pulled out, need help! searched (Duane_in_Japan)
O2S.......................... Engine Harness
BLACK.......................... GRN / RED
BLACK.......................... BLK / YEL
WHITE.......................... BLU / RED
GREEN.......................... ORG / BLU
BLACK.......................... BLK / WHT
BLACK ..........................YEL / BLK
WHITE............................. WHT
GREEN ..........................GRN / BLK
Old Aug 8, 2005 | 08:50 AM
gsr dood's Avatar
i had the same problem i just kept tryin a diffrent order untill the cel light went away good luck
Old Aug 8, 2005 | 10:24 AM
tur3oDC4's Avatar
Default Re: 4 wire 02 sensor, pulled out, need help! searched (gsr dood)
hey thanks for the help guys, i'll try it out. BTW its a 95 LS
Old Aug 9, 2005 | 02:30 AM
O2S....................................Engine Harness
BLK..........................................ORG / BLK
BLK..........................................YEL / BLK
GRN..........................................GRN / BLU
WHT........................................WHT / RED
Old Aug 9, 2005 | 02:32 AM
This is the 95 Integra with single O2 sensor (Integra forum = Integra car???) but these colors seem to match and you said your dont match???????????
Old Aug 9, 2005 | 04:58 AM
CNSK's Avatar
good info....I needed that too
Old Aug 10, 2005 | 02:35 PM
tur3oDC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">O2S................................. ...Engine Harness
This is the 95 Integra with single O2 sensor (Integra forum = Integra car???) but these colors seem to match and you said your dont match???????????</TD></TR></TABLE>
let me check it again, i, pretty sure they didnt match up, or i could of figured green to green out lol. Thanks a lot for the help guys.
accrdpusha
Sep 16, 2005 04:09 AM
CrxEDguY
Feb 7, 2005 07:53 PM
Civic Hx-T
34
Mar 2, 2004 05:15 AM
NonovUrbizniz
Oct 16, 2003 09:14 PM
cannon_man
Jun 30, 2002 09:21 PM
